Brake Line size
Hmmm, I don't see why the brake lines need to be 3/16" instead of 1/4." When the brakes are applied, not much fluid moves through the lines, but the amount would be limited by lines that were TOO SMALL, rather than too big. One possible factor is bending radius - smaller diameter lines can be bent around a smaller radius, but if you have plenty of room, 1/4" lines should work just fine.
on
with brake lines, you're not dealing with volume... you're wanting pressure.. the small lines give you a higher pressure. the standard master cylinder is designed to give adequate brake line pressure with 3/16" lines. it can't give that type pressure when trying to 'push' fluid thru 1/4" lines.
There is some really good brake information on C.H. Toppings website.. www.chtopping.com.
Brakes have been engineered for years with 3/16 lines... I don't think this is an area where I' like to experiment
later
john
later
john
Yesterday was such a disappointment of learning the length of Brake Line I bought had metric threads....returned it today , got one w/ American threads, bent it and installed it for the rear. Rear done / awaiting braided brake lines from CCP for the front......so....It's coming along. Thanks for all the info.
