Gas vs Diesel? (4X4 Project)
Without Mr. Banks the diesel would still be just an engine for delivery vans . . . But his engines are slow to react - they take a while to spool up.
I was more wondering how that heavy front end plowed through the mud - I know they are helpless in the slick as 2wd - do they perform with a gas rig in 4wd?
All depends on the engine & the setup. The IDI Fords may have the rpm to do what's needed, but not the hp. A Cummins has cheap hp potential, and can get the rpm's we need, but they are pricey. A DT360 IH, is nearly identical to the Cummins, except the overall size makes it hard to fit in. An early powerstroke may be about the best bang for the buck, but power is expensive. Either case, it's an increase of 300 pounds over the 460. They dont need Mr. Banks to get good power. A fairly modded diesel can stomp a 460.
Originally Posted by nevrenufhp
. . . The IDI Fords. . . .. An early powerstroke may be about the best bang for the buck, but power is expensive. Either case, it's an increase of 300 pounds over the 460. They dont need Mr. Banks to get good power. A fairly modded diesel can stomp a 460.
Also, what is IDI? And I expect we are talking about late model stock trucks - maybe with some special computer programming but without any internal mods.
IDI is the 6.9 & early 7.3's which means InDirect Injection. Maybe with a diesel's added torque, you could run a higher set of gears & get more wheel speed, considering it was not a stock diesel. Stock, as in, stock fuel & hp level. For reasonably cheap you could get a Cummins to 500hp & 900+ pounds of torque. Getting it to the ground costs the bigger bux.
My rig (diesel) is a blast in the mud, i`ve got 305/75/16 BFG with a leveling kit that raised me up 4 in. in the front and added a leaf in the rear for 2 in.I`ve had my tires almost buried (in height) with mud and pulled right thru. I can`t see any diff in gas vs diesel other than weight. I go to Tahoe fairly regularly and it loves the snow, forest,and it`ll climb anything with all that torque. The only time I didn`t enjoy was down at Pismo in the sand,I didn`t get stuck but it was close
anyway that`s my ramblin,time for a suds
Hanklin
Hanklin
