tired 5.4
Unless it's been abused-129K miles is really just getting good and started with a modular. I'd say check spark plugs and replace if they're over 30K miles or so,and clean the MAF sensor.At that mileage-it's also possible that the primary "light off" cats are bad or clogged,and need to be replaced.
JL
JL
Sounds just like my F-150 I just traded in.
OK, does the engine seem to lay down when you press on the gas? Does it seem to start OK but as you accelerate the power just isn't there?
If so, you're catalytic converter is probably clogged. To check, disconnect your exhaust at the Y pipe and take your truck for a (LOUD) spin. If she runs good, you've found your problem.
Originally Posted by superbeast333
it starts fine but when you accelerate it just aint there.It will have to downshift at most hills and pulling an empty landscape trailer felt more like a semi trailer.At 90k it had good power but it just goes down from here.
JL
I just cleaned the MAF,new air filter,and checked the PCV valve and there is vacuum.Would it be necessary to change the plug boots or just the plugs and how hard is it to change the fuel filter on one of these?Thanks alot.
