new turbo at 2,058 miles
Is that a record?
Well I finally had to bring my fire companies 06' F-350 back to Ford for its first warrenty repair. Friday night I had to move the truck to do some work and while I had it out I figured Id go for a spin and exercise it. Well to my disappointment, the truck had absolutely no power and about 5 blocks later the check engine light came on.
So I took it back to the station, let it sit outside idling for an hour while I did the work I had came to do, then took it for another ride. It seemed a little better, but definately wasnt right and the dash light was still on.
Called Ford saturday morning and made an appointment for tuesday (today). Brought the truck in at 8:00am and gave the service guy all the needed info. It was rather funny when he asked me the mileage, I told him 2,058 and he types in 20,058...... Im like no, one too many zeros in there, it really has 2,000 miles on it, he seemed rather surprised but Im not really sure why, its not like the 6.0's are trouble free, lol. Service manager calls me around 4:00pm to tell me the truck was fixed, the turbo was bad and replaced and they also fixed an oil leak coming from the crank case vent.
So needless to say it was a pretty painless day, for me anyway, and my baby is fixed so I can stop worrying about it now.
Just figured Id share my story incase there were other low mileage owners out there with similar problems.
Ford has bulletin out on prolonged storage or non use. The vanes in the turbo rust shut from moisture. So no your problem is nothing new or record setting.
I guess Ford will be replacing the turbo ever year if thats the case cause Im not gonna put wear and tear on a vehicle just to keep the turbo free
Garret caused the problem, Ford did not, you should have the updated turbo now.
The service manager was gone when I went to pick the truck up so I didnt get to chat about the problems or remedys but hopefully the updated turbo will do the trick
well i can tell you that the turbos are not bad. the vv turbos are only second to the TT setups. now, you have to drive these trucks, and i am sorry if you dont like that but you have to do it. i haved a truck at our local fire dept. that is the same way and they drive it at least once a week, and it has had no more issues without turbo replacement as of yet. i wish i could tell you a easy fix, but i cant. if you dont like the fact that you have to drive the truck, then you will have to deal with whatever issues come about.
What about a brand new one? I got mine new and it seems to be getting better. Could it (the vanes) be sticking some? Should I try to fob it like a boat motor or something crazy like that. It does seem to make pleaty boost now. Around 28lbs. Just wondering.
We had the same problems with our 05 E450 ambulance. In the shop at least 5 times in the first 7000 miles. These engines just can't take the way we use them.
Many of the other FDs and EMS service guys I've talked to share the same problems.
What's even better is that we'll be replacing our 96 PSD with one of the new 6.4s. I sure hope it's a lot better for the sit, floor it, idle, floor it, idle, sit type of work that we do.
It is 100% inexcusable to say that you have to drive an engine and drive it hard for it to work reliably.
Mike
Mike
I guess that depends on the recommendations. If Ford built an engine and said never let it sit idle for months, and you insist on doing it, it isn't Ford's fault if it fails. It's not like they aren't covering it under warranty.
On another note, don't you want the truck to work when you need it to go put out a fire or pick someone up in an emergency? Not doing what is required because you feel like you shouldn't have to, just sounds irresponsible, but that might not be what you meant.
Originally Posted by NJTy180
I dont have to do anything. Ford can just keep replacing these POS turbos for free until its out of warrenty, then Ill simply slap on a real turbo that has a wastegate and solve the whole problem right there. Either that, or we'll replace this truck with a Dodge
As far as not wanting to use it, yes it definately shouldnt have to be used in order to keep it in usable condition. Just because Ford has come out and said this would help prevent a problem with their product doesnt make it right by any means.
As far as emergency use, the turbo problem just leads to a lack of power, not total disability of the vehicle, so it could still be used if needed, not to mention we have a 7.3L PS F-250 to use for backup if it came down to it.
go get a dodge. they have the vv turbos as well. if you put a turbo on a 6.0 with a wastegate, you will never get the performance out of your engine like you would with the vv turbo.
My personal truck has a standard wastegate turbo and its performance and reliablity is just fine.
and if Dodge uses vv turbos, why doesnt Dodge have all these problems like Ford does? Hummmm??? I know plenty of '03+ Dodge owners, some with very low mileage trucks that sit outside thier whole lives, they dont have to take their trucks in for new turbos all the time. Makes ya wonder doesnt it?
For as long as I've been working in this trade, underuse of vehicles has been as much as if not more of a problem than over use. Whether it's a Tempo with seized wheel cylinders, or a 6.0 with a rusted unision ring, underuse in a humid environment will cause rust. Not Fords fault, they just can't control the weather... YET.
NJTy180---The experience that bowtiehatr, canadaguy, myself, and the other techs here are not laboratory findings, that much is correct. Our experience has been hands on, wrenches turning, bloody knuckles type of experience. We see what goes wrong with these vehicles close up and personal. To doubt what kind of experience these people have without even knowing them is irresponsible at best. Come to think of it, what proof can you give us that you even have a relationship with a fire company? Do you sweep the floors? You see, it works two ways. The techs here spend their time offering help to anyone that asks for it. Now, if your information says putting on a wastegated turbo will fix that problem, it will---but it will perform like a yugo with a plug wire off. Here, the emergency services dont use dodges because they arent reliable enough. That must mean that the entire country is the same, right? Thats using your logic!
