Hazy windshield?
Hazy windshield?
I know I saw somewhere before how to remove the haze from inside the windshield but I can't find it now. At night when you look out the window at oncoming traffic it looks like you need to use the defroster, but it looks like this all the time year round. Anybody know anything to do or something to buy, other than replace the window?
"Sprayway Glass Cleaner" works really well. You might get a kitchen sponge with the scrubber a hold of it too (with the cleaner) to start with.
I've noticed some haze can actually be left behind by some paper towels (they have some oils or something in them) and even by clean cloth towels. Use a cloth towel(s) that's been washed in a plain detergent (no perfume, dyes, fabric softeners) and hot water. Wash your hands with a plain soap (again, nothing with moisturizers and such) too if you want to get picky.
Originally Posted by 5.8F250
Is there a sweet smell in the car. If so when the heater core go's it will create a haze on the windshield. Just saying this to eliminate possibilitie's.
Not to be mean, but I know what a heater core going bad smells like and what it does to the car. The carpet is bone dry and the only smell in the car is that of my royal pine air freshening tree hanging from the mirror. The haze doesn't go away with normal glass cleaner and any rag that I can get my hands on, paper or otherwise. The haze is like a permanent cloudiness to the glass. I know that somewhere on here a long time ago there was somebody who said what caused it and how to fix it, but for the life of me I can't get anything to turn up by searching.
They make glass polish (abrasive), if anything will take it off it would be that. An high speed drill helps. You might check your insurance and see if you have a windshield allowance. I'm getting mine replaced in a couple weeks from "sandblasting" damage (all the tiny rocks and debris that pit the windshield after a while).
its the same thing as when your headlights get hazy. the haze is a bunch of fine scratches on the glass. with headlights you sand them down with a very fine sandpaper and the apply 3m rubbing compound, and then there spotless. i would think a light abrassive cleaner and a buffer would have a similar effect on a windsheild. then add some kind of rubbing compoud to fill in the remaining scratches. i like the idea of the rain x. just my 2cents
Originally Posted by tewferford
It may not be the glass itself. It could be the laminate between the two pieces of glass that is hazing. Have a glass repair shop look at it.
Frank
Frank
http://autorepair.about.com/library/...uto+windshield
