ZF 5-speed in a 79
ZF 5-speed in a 79
I have 79 F150 4X4 long box that I would like to fit with a 460/ZF combo. I have the 460 and I have a line on the ZF/transfer case combo.
What I need to know is if a crossmember exists for the transmission or if someone has come up with a way of fabricating one.
The transmission has a mechanical spedometer hook-up. I am assuming that I can get a speedo cable to work with the correct gear.
The transmission would come with the wiring harness. I don't really know if the harness serves any really purpose given that the truck would be a non-computer controlled truck.
Has anyone switched a late 70's ford truck over from a linkage style clutch set-up to a hydraulic set-up?
I don't know exactly what model transfer case it has attached to it at this point, but what would be the "ideal" transfer case to mount to the ZF if I had my choice?
Any help would be great.
Zf
Don't worry about the ZF's aluminum Tcase, Use your NP205! You only have to clearance grind the rear flange a little to allow the 205s shift rods to clear. NO BIG DEAL! That way you don't even have to mess with your driveshafts. I have installed one in a 1979 F150 supercab 4x4, works mint, I used a hydraulic clutch system but if you are using the stock 11" clutch, you should be fine with original linkage. You'll love the shifting, and RPM drop.
Check out my gallery, I did this same swap. You're going to have to move the crossmember back a little bit, but the ZF trans mount bolts up to the '79 crossmember. For the speedo cable, I used my 205 case which the speedo is run off of. If you have any other questions, feel free to ask.
Chris
Chris
Has anbody swapped in the hydraulic clutch setup? I am converting from a C-6 to a 5-speed from a bronco.
Just found some info, but is it essentially an "easy bolt up"? I will have everything I need from a hydraulic clutch truck...
A bit of fab work for the hydraulic clutch. With the 460 it's easier to use mechanical I think. With the small block like me, I have no choice but to go hydraulic because of the concentric slave cylinder, but I won't be attempting that until this summer at the earliest.
solidrunner, is that a stock 4x4 crossmember? The 2wd crossmember is much different, and I'll probably need to fab one that looks like yours for my swap.
With a 2wd you definitely need a new xmember, the bottom flange on the frame starts to slope upwards right behind the xmember, you can't just move it towards the rear. It's either make a drop hanger like solid's, or put a jog in the middle of the stock xmember. Now that I think about it, a drop member would be a less favorable option on a 2wd. Thanks for your input samick.
4 wd crossmember....
Rather than move the crossmember on my F150 4X4,I just cut a rectangular notch in it on the middle of the bottom to clear the tranny case.I still intend on boxing in the notch although it hasn't shown any sign of cracking around it.[This is on a four wheel drive application,no idea on a 2wd.]
