ZF 5-speed in a 79
Old 10-05-2010, 11:12 PM
fairlane68's Avatar
fairlane68
fairlane68 is offline
Now for a can of revive-a-thread.
First off, I'll say that the Facebook login thing fails miserably. Automatically logs you out and you can't change anything in your generated profile. Generates an invalid email address, so you can't create a password.
Secondly, I've been here before, but only as teh result of a Google search. Now I need answers to questions that have yet to be answered. Yes...I searched. Search Link
I have a '76 F-250 with the 4.9L big six. I like this engine. The truck has a 4-speed, I want a ZF 5 speed, which I bought today for $300. Mine uses the hydraulic release bearing. This is also my personal preference. I was never a fan of 9 million moving parts for a clutch linkage, too many parts that can fail. Has anyone done the ZF swap and used the hydraulic release bearing? I need details and pictures. I'd really appreciate any help. I don't need another long-term project. That's why I have a Mustang.
Old 10-06-2010, 12:25 AM
68Mercury250Ranger's Avatar
68Mercury250Ranger
68Mercury250Ranger is offline
Swap?
all you need to do is fabricate a lever the correct length(hydraulic) to your existing clutch pedal assembly. basically remove the "down" rod, and install a "forward" short rod off an 85-96 F150 firewall, and stick on the clutch master. you may need a reinforcement brace . but its a pretty clean job.
Old 10-06-2010, 10:44 AM
fairlane68's Avatar
fairlane68
I think I know what you're talking about, and I've installed one of those braces before as a Ford Technician. Which side of the brake booster should the master cylinder be installed?
Old 10-06-2010, 12:55 PM
doug70's Avatar
doug70
doug70 is offline
left
The clutch master will mount on the left of the brake from the drivers perspective. I ended up making this cross member. Mine is an NV4500, but the principal is the same.
Be sure to reinforce your firewall, they tend to crack. If you can cut a small section from the donor cab, that should do it.
If you are going to run headers, the shorties work pretty well with this setup.
Doug
Old 10-06-2010, 04:48 PM
fairlane68's Avatar
fairlane68
Thanks. The reinforcing kit (for the late 80's trucks) from Ford is about $25, and I have plenty of sheet metal I can use for bracing. Fabbing a crossmember is no problem. I'm just waiting for everything that was ordered to come in. I'm staying with the big six, but even with a header, clearance isn't going to be a problem. Once I get started on this, I'll take plenty of pictures and make a write-up.
Old 10-07-2010, 11:57 AM
doug70's Avatar
doug70
doug70 is offline
thanks
Keep us up to date. The 300 is a workhorse. I almost went that way myself. I had one pulled from the donor truck and preping it when I changed my mind and went with the 351W.
Doug
Old 10-07-2010, 04:25 PM
fairlane68's Avatar
fairlane68
Definitely. Just about every truck I've owned has had a V-8, and the one that had an inline six was the one I enjoyed the most. Switched to a 4bbl and header, and it woke that truck up. Made it alot of fun to drive, and very unique.
Old 01-15-2016, 04:34 PM
bulldozer77's Avatar
bulldozer77
bulldozer77 is offline
I have a 1976 F250 four-wheel-drive that had a 360 in a four-speed I am replacing it with a 460 and a 95 Zf 5 , how is the conversion ,with transmission crossmembers and whether to use the existing clutch or to convert to a hydraulic
Any help appreciated
Thanks
Old 01-15-2016, 04:39 PM
doug70's Avatar
doug70
doug70 is offline
Thanks
I haven't gotten back to my truck. I hope to this fall. After a divorce I moved back home. The truck is 2000 miles away. I'm going to pick up some stuff in March and the truck in the fall. My plan is to use the hydraulic clutch from a late model ford.
Old 03-10-2017, 12:37 PM
F-250 restorer's Avatar
F-250 restorer
F-250 restorer is offline
I hope this thread is not dead.
I have a 75 f250 with a C6. I'm changing to a ZF. Will the ZF fit under the trans tunnel of a dent side?
I was wondering if I'd be better off cutting the tunnel out of an efi with a zf and just installing that on my truck. The ones I've seen seem to be higher at the f.wall, and I thought that may be an issue on our trucks.
Old 03-20-2017, 10:02 AM
kenmt's Avatar
kenmt
kenmt is offline
I didnt have to trim much off my 77 F150,just where the lip is on the firewall where two pieces come together.I used a C6 floor pan because the shifter comes uo through the floorpan quite a lot further forward than the original 4 speed so a new hole had to be cut anyway.
Old 01-15-2021, 10:34 PM
Elysees's Avatar
Elysees
Elysees is offline
Images
Originally Posted by solidrunner
Check out my gallery, I did this same swap. You're going to have to move the crossmember back a little bit, but the ZF trans mount bolts up to the '79 crossmember. For the speedo cable, I used my 205 case which the speedo is run off of. If you have any other questions, feel free to ask.
Chris
Hi there, do you still have the images available?
  #28
Old 01-15-2021, 11:18 PM
solidrunner's Avatar
solidrunner
solidrunner is offline
I do not, that was almost 15 years ago.
  #29
Old 01-16-2021, 01:07 AM
F-250 restorer
I completed the install about 6 months ago. I did a thread with a lot of pics. I'm sure you can find it.
Here is my thread: https://www.ford-trucks.com/forums/1...all-stuff.html
jcorbin79
12-21-2010 02:30 PM
79street/bogger
01-30-2010 08:56 PM
mando jake
07-10-2007 11:18 AM
1973F250CREW
09-27-2006 07:20 AM
Silver Bronco
1978 - 1996 Big Bronco
12-15-2003 06:34 AM
Quick Reply: ZF 5-speed in a 79
