98 4.6L timing chain and sprocket alignment questions
well ok i put the cams back in and put the timing components back in and i turned it over and she will spin over and over now. i have the front cover off and it making a little chatering noise but since everything is new i think it just sounds that way until i put that cover and components on. i think it should be alright. ill have to do a compression test check on it after i get it all done just to see about those rings. this motor has 177k miles on it and if i am going to have problems with it when im done im just going to have to get another motor. do any of you know where is agood place to get a crate motor or a good place to get low milage motors?
68shortbedmo
Modular V8 (4.6L, 5.4L)
07-15-2014 08:53 PM
