2wd guys in here
2wd guys in here
Im curious what the compressed height of a coil spring is under a PSD. The upper to lower mounting surface distance while under the weight of the vehicle. I looked at my axle yesterday and had a good idea on how to run a coil set up on a D60.
Also, if you have front sway bars, do they mount to the frame just behind the bumper below the rad in that area?
