Timing Marks on 2001 Ranger 3.0
Old 12-15-2006, 02:54 PM
BNSFMoW's Avatar
BNSFMoW
BNSFMoW is offline
I'm getting ready to change my CPS and synchronizer. I cleaned off the damper and found the timing marks on it but I'm not completely sure what to line them up with on the timing cover. There isn't the usual kind of pointer I've seen before. Just to the right of the crankshaft sensor is a sort of triangular nub cast into the timing cover. Is this the pointer I need to line up with my TDC mark? I checked in the Haynes manual and they don't show any pictures or give any kind of description.
Thanks for any help.
Old 01-05-2007, 10:55 PM
amish77's Avatar
amish77
amish77 is offline
in general a triangle mark is the pointer that you use. If the rest of the surface is clean and there isn't another mark then I'd say use the cast mark you're describing. Just not sure why it's on the crank and not the cam, which is where I'm used to seeing them.
1968f100
34
07-23-2019 09:47 AM
abyars111
10-04-2014 06:57 PM
mnewbolds
09-15-2014 05:19 PM
Gregory Glaser
09-02-2012 08:38 PM
Supergordo
11-13-2011 11:36 PM
Quick Reply: Timing Marks on 2001 Ranger 3.0
