Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation & A/C
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Cooling, Heating, Ventilation & A/C SPONSORED BY:
Click Here
  #1 (permalink)
Old 12-13-2006, 04:34 PM
thefarelaneman thefarelaneman is offline
Garage is empty, add now
thefarelaneman is starting off with a positive reputation.
labor flat rate time
I am looking for a sorce on line that can give me the time alowed for repairs. I know the dealers have one but they guard them from the public. I plan to fix a friends car for free and just wanted to know how many hours a dealer would charge for this.
  #2 (permalink)
Old 12-13-2006, 04:50 PM
arctic y block's Avatar
arctic y block arctic y block is offline
Old School
1962 Ford F-100
arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.
Got mine from Nappa. I believe they trained a bunch of midgets till they got the fastest time and use that. If your shop isn't top of the line computerized and you haven't done it at least 50 times you will not match there time. I have had three shops running at the same time and if the book said 1.5 hours for a job than no mater what happened or how many days it took you can only charge the flat rate. That tell ya why the rates are so high?
__________________
85 XLT Bronco 351W HO 4V Dual Pipes 33X12.5 BFG's
62 Uni 390 C6 Custom Cab Not Yet Sold
Looking to buy a 48/50 F Anything If ya have one contact me.
Don't just Modify it Fordify it
  #3 (permalink)
Old 12-13-2006, 06:16 PM
HomerWinzlow's Avatar
HomerWinzlow HomerWinzlow is offline
HomerWinzlow is gaining momentum as a positive member of FTE.HomerWinzlow is gaining momentum as a positive member of FTE.
From my experience, many of the flat rates are simply a percentage over the factory warranty rate. Problem is warranty often includes some additional addons for certain labor operations added to the main job. This is OFTEN overlooked by the motor guide and the others.
There are also certain jobs that they are way over the actual time that would have been charged by the dealer. Go figure how they arrived at that. Maybe because we know shortcuts that they cant figure out.
In any case, a labor guide is just that ... a GUIDE. Shops can choose to over ride it when there are obvious mistakes.. But dont bank on many techs giving you a break when the book is in their favor by a wide margin... just the facts of life.
In some shops they charge the minimum number of hours and pay the tech based on that. Then they charge a huge bloated hourly rate to cover thier butts, leaving the techs eating the loss.
__________________
My advice is just advice..Its free "IF THAT DONT FIX IT, SOMETHING ELSE WILL"
The most expensive tool in your box is "impatience"
IF IT AINT BROKE DONT FIX IT!!
My Missing Michelle
  #4 (permalink)
Old 12-14-2006, 12:22 AM
True, I worked as a dealer tech and know how to read the manual ,I just dont have access to one as of yet. I assume the radiator R/R will give a time of 4 to 6 hours .
  #5 (permalink)
Old 12-14-2006, 05:44 AM
On most Fords the R&R time for a radiator is 1 to 2 hours. A Taurus is about 4-6 hours but that is one of those that may be well over its actual due to improper sequence or access. It would definitely be difficult without a rack.
__________________
My Missing Michelle
  #6 (permalink)
Old 12-14-2006, 11:14 AM
OH LORDY.The car is a 97 Tarus,,,,,,,,,,,,,,I have some large heavy duty stands and will try to raise it,If not,oh well, and I promised the wife I would fix her co-workers car........
  #7 (permalink)
Old 12-15-2006, 07:32 AM
projectSHO89 projectSHO89 is online now
projectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to all
Quote:
heh! Proof that no good deed goes unpunished.....
Steve
__________________
2001 F250 SD V10 4x4
HVAC FAQs: http://www.ford-trucks.com/forums/75...xpedition.html
Owner's manuals: https://www.fleet.ford.com/maintenan...ls/default.asp
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.” - Mark Twain
Tags
book, charges, flat, flatrate, ford, fords, guide, labor, labour, rate, rates, shortcuts, time, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
