Limited slip 9"
Correct me if I am wrong, the 3.50 9" came in the 80s (ex: full sized broncos). A 1979 truck would have the 3.54. As people pointed out, no case difference.
As for splines, it is pretty simple.
Remove the wheel, remove the four nuts (usually 3/4" and you can use your lugnut wrench) holding the retainer plate, and pull the axle out. Once I get the axle part way out, I put a nut back on to keep the backing plate from coming off.
If the axle appears "stuck" sometimes you will need to use a slide hammer to remove the axle. BUT, I have never had to do this on a older truck, usually rotating one or both tires with the rear housing jacked up and both wheels off the ground will let you slide it out. Reason for having both sides jacked up is the housing does not deflect and this makes getting the axle out easier.
Just lift the axle out straight so you do nothog out the inner seals with the axle or its splines.
It is not that tough or time consuming. You will want a rag so you do not drip fluid all over the place. It does not hurt to have the side you are working on slightly higher so the fluid flows to the pumpkin.
The only for *sure* way to check the splines is to pull the axles and count the splines like rebo says. Almost all trucks got 31 spline axles.
Don't buy a minispool. You want a limited slip. Like Rob (monsterbaby) says, everybody and their mother makes some sort of traction aid for a Ford 9".
There is no such thing as a 3.54 for a 9 inch axle. If you have an 8.8 rear axle then thats another story but not in a 9 inch. The front D44 axle would be a 3.54. There is always a slight difference beteen the front ratio and the rear ratio.
In and around 84 ford started to use the 8.8 and the 9 inch axles in the F150 trucks. About 86 they all should be 8.8 axles in the rear. From about 77 or 78 I would safely say that all the F150 trucks are 31 spline axles. I've seen 28 and 31 spline axles in vans which is a good place to look for a good used trac loc.
I'm not doubting you...it's been a while since I looked up parts for a 9 inch.
btw...the 8.7 was introduced in model year 1967.
Maybe I'm thinking of an 8" 3:54?
