Getting my heavily modified F250 through Californina Emissions
I might be moving to California for a new job after I graduate. My 77 F250 has a 460 in it that is running close to 500 HP. No cats, no egr. I thought I read something about a 30 year old rule and then it's exempt from CA emissions? Is that true? Is there a way to get it around CA emissions? If I have to, I'll leave it in WI for few years until it is old enough. I was just curious and thinking ahead and watching out for my truck.
There is no more rolling exemption in California. Anything newer than model year 1975 requires bi-annual inspections. It will also require a smog test to register it the first time when you bring it in. It is only required to have the original smog related equipment it was manufactured with, so if it never had cats it doesn't need them now. Also, some counties require dyno testing and some do not. Where I live we do not need dyno testing. My truck has no cats, egr, evap system and a Carter AFB and I got it to pass. It's a 76 SC from Washington State with a 460.
There was discussion of another 49 state truck being operated in Calif.
It was exempt as it was not a Built for California operation.
The truck came from an Eastern state with a young lady living and going to school in CA for 4 years.
That thread is in one of the California chapter forums.
Originally Posted by 77bigblock
The job is for Union Pacific. CA is just one of the places that's a possibility. I'll just have to deal with it when the time comes I suppose.
What job are you looking at? :)
Alvin in AZ (retired SPRR signalape)
I applied for Transportation Associate, which is on the management sides of the operation. I have an interview on Jan. 9 in Chicago. I've heard and read that they're hiring for California like crazy, so I'm just doing my research ahead of time. So, what did you do for the Southern Pacific?
on
Nope no more rolling exemptions I'm afraid. I was told that 1976 and newer will never become exempt by the DMV. But things can and have changed before.
From what I was told the truck must have the original (when new) smog equipment working and functioning properly, either be it 49 state, or California emissions, it must be there and working.
Smog is also ran by the state of California. The counties have very little to do with it other than if you need to do a standard test, or a dynometer test.
Things they search for before and during the tests are...
A: EGR Valve function test.
B: Unleaded Fuel Tank filler restrictors and markings.
C: Charcoal Canister and Fuel evaporation system. (Currently they do not check for functionality, but it's in the planing stages)
D: Gas cap pressure release and seal test.
E: Heat Riser System present. (They dont check for functionality).
F: Check for catalytic converters, holes in exaust system that may dilute readings at the sniffer.
G: Electric choke. A manual choke is an automatic fail unless it came with the truck new.
H: Aftermarket engine parts such as headers, carbs, intakes, cams, etc... that are not registered to be and do not have a California Smog Compliant number is a automatic fail.
I: Thermactor system and components .
Etc... etc...
I've failed the test for a faulty gas cap etc...
Hope this helps...
Etc... etc...
Hope this helps...
on
Originally Posted by tractoman
...and there are no counties that do not require smog testing. They all require smog testing every other year.
Doesn't sound like it's gonna be an easy fix for him. I know a guy who brought his '86 down from Washington with a built/stripped 460 in it, no way it would pass. The body was trashed anyway so he bought an '85 with a clean, straight body and a worn out diesel, registered it in his name and then took everything out of the '86 and swapped it into the '85. If he gets pulled over and they get to wondering about it since it's registered as a diesel...well, I'm glad I won't have to pay his fines...
