1959 F100 4wd drivetrain
Where might I find a good rundown or description, history, etc, of the 1959 F100 4x4 drivetrain? I understand 1959 was the first year this was offered to the general public, and I think I have a good line on one. How rare was the 4x4 option in '59?
Any direction would be great,
brider
brider
Standard Ford rearend, 9" in 1/2 tons, Spicer 60 in 3/4 tons;
Dana 44 front for both;
Ratios: 3.92:1 for 1/2 tons, 4.56:1 for 3/4 tons;
Spicer 24 transfer case for both;
223" I-6 standard, 292" Y-8 optional;
3 speed standard, 4 speed T98 optional.
I don't know off-hand the number of 4wds. Suffice to say it would be a low percent of total pickups built in 1959. Yes, '59 was the first year of the factory-built jobs.
on
The following users liked this post:
Yes, it was a rare truck. Back then only power line companies, const. companies, Govt. forestry agencies, etc.. used them. The general public wasn't using them much. The 4x4 boom didn't take off until the mid 70's as the manufacturers started to push them. Any 4x4 from that era is worth saving to restore or parts for others.
Barry
Barry
Dana Spicer 24 gear ratios for high range is 1.00:1 and for low range is 1.86:1
Do you have a VIN number?
Also inside the cab near the back there is a triangular piece of metal welded on each side of the cab I believe to stiffen the cab for 4x4's. I haven't seen this on 4x2's. Also the steering box utilizes a different case and sector shaft but uses a 1 ton shaft and worm. Good luck getting your 4x4. I have a 59 1/2 ton 4x4 and 60 3/4 ton 4x4. Let me know if you need any more help. Parts are hard to find but not impossible. They are great trucks and easy to work on.
old uhaul
11-18-2015 06:53 AM
fordguy_460
11-05-2011 11:42 PM
3360stepp
10-03-2010 11:05 PM
brider
07-23-2007 08:33 AM
