Disable seat belt chime
Old 12-08-2006, 06:11 AM
1Knight's Avatar
1Knight
1Knight is offline
First, I always wear my seat belt....... I don't need to be reminded.
If I am backing up to hook the trailer, or just moving the truck in the driveway, it's a pain in the neck to hear back-up, seatbelt, parking brake chimes.
And even moving my truck, the parking braking is chiming, but I think it's the seatbelt, so I ignore it.
What is the best way to disable it? Or better yet,where is the chime?
Old 12-08-2006, 06:15 AM
Cam_Man595's Avatar
Cam_Man595
Cam_Man595 is offline
Your owner’s manual explains how to turn it off.
Old 12-08-2006, 06:48 AM
skycop530's Avatar
skycop530
skycop530 is offline
I disabled mine because of the same reason. It's easy to do.
Old 12-08-2006, 07:53 AM
Lonewolftx's Avatar
Lonewolftx
Lonewolftx is offline
Question Hey . . .
What I want is a turn signal still on chime! Can we rewire the seat belt, key, or headlight chime to do this?
Just a thought . . .
Old 12-08-2006, 07:59 AM
Hjudge49's Avatar
Hjudge49
Hjudge49 is offline
One of the first things I do on a new truck is to disable the chimes. To disable the door open/key in ignition chime, remove the ignition switch and tape over the small brass tab in the carrier. To remove the switch, insert a thin phillips screwdriver of a nailset in the small hole under the switch, and depress the plunger, turn the key and the whole assembly will come out. You will see the brass tab in the well.
Old 12-08-2006, 08:11 AM
kw5413's Avatar
kw5413
kw5413 is offline
When in need. Always check our tech folders. A wealth of info is available.
https://www.ford-trucks.com/forums/4...oor-chime.html
puckett_jw
2017+ Super Duty
18
06-24-2018 07:12 PM
ketel0ne
1999 to 2016 Super Duty
04-15-2014 09:10 PM
John Irwin
09-18-2010 08:12 PM
fnx4wheeler
08-31-2007 05:37 PM
peckdog4
12-05-2001 09:16 PM
Quick Reply: Disable seat belt chime
