Front axle pivot bushing replacement
Old 12-05-2006, 03:33 PM
dbrown13's Avatar
dbrown13
dbrown13 is offline
Hey guys/gals, I have a 94 F150 2wd with worn out axle pivot bushings. From what I can tell these are pressed into the I-Beam. What is the best method of replacing them, and when the bolt is removed from the bushing, what direction (up or down) is the axle (I-Beam) going to swing? I have air tools, impact wrench, air chisel, etc and plenty of room to work. I need all the advice I can get. I just got through replacing the Radius arm bushings. What a PITA, but I cheated and cut the rivets.
Old 12-07-2006, 05:22 AM
SRD4X4's Avatar
SRD4X4
SRD4X4 is offline
I use my balljoint press to remove/install the bushings.The axle is going to move UP.
Old 12-07-2006, 08:27 AM
dbrown13's Avatar
dbrown13
dbrown13 is offline
Thanks for the info, sounds like its not going to be as bad as I thought, as I am eventualy going to have to do 3 more F150's and one Ranger after this one. Two of the F150's are mine, a short cab short box 91, a SCab 93, my dad's 93 F150 SCab, 94 SCab 150, and his 88 Ranger SCab 4x4. Again Thanks for the reply
Old 12-10-2006, 09:22 AM
LeoJr's Avatar
LeoJr
LeoJr is offline
The bracket on the Passenger side, next to the converter is all bolts. But mine is a '96 so this may be why.
The Drivers side is still all rivits. What size bolts did you use?
Did you use factory rubber or some aftermarket polyurathane?
Also, have you replaced the rubber at the truck end (as opposed to the wheel end) of the I beams?
Old 12-10-2006, 12:44 PM
dbrown13's Avatar
dbrown13
dbrown13 is offline
Got em replaced, I used a jack under the I-Beam where it attaches to the frame and removed the bolt. I then lowered the I-Beam and pressed out the rubber bushing with a ball joint press which left the steel outer in the I-Beam. I carefully cut out the steel outer from the I-Beam with an air chisel. I then pressed the new bushing into the I-Beam and raised it into position whith the floor jack. It did not line up as the wheel and beam had moved outward. I used a wire stretcher to pull it back into position and installed the bolt. repeated procedure for the other side. It drives like a new truck. Thanks for the tip on using a ball joint press.
warren561
01-21-2022 03:12 PM
andyz77vette
07-02-2011 10:54 AM
smashclash
11-28-2010 12:37 PM
Nick_Good
03-02-2010 06:06 PM
69F350
08-25-2001 01:09 AM
Quick Reply: Front axle pivot bushing replacement
