Dual Fuel Tank problem
I have a 1988 F-250 2wd V8 with dual fuel tanks which are equipped with a switch in the cab to go from front to rear or vice versa. My problem is that when the rear tank is filling the front tank when I am using the rear tank. Example: front tank has 1/4 tank when using the rear tank after about 40 miles the front tank is just about full. Anyone have any ideas. I don't use the front tank due to I have to replece the filter.
Thank You
Mark
Thank You
Mark
Originally Posted by SilverSport
SubFord .... I think it would be the front tanks pump with the problems since that is the one crossfilling. I know the 88 is a different system than my 90, but don't they both use the same filter?
Lil Josh
16
11-08-2008 06:24 PM
