3inch body lift on 79 f-150
hey guys I have all of the lift blocks for a 3inch body lift. I want to install it on my 1979 f-150. I heard that the body lifts are hard on the body mounts is this correct? Also I was wondering what all needs to be modified to put this 3inch lift on my truck? Also is there anythign else i will have to buy so i can put this lift on my truck? remember i only have the lifting blocks thats all.
thanks,
Jimmy
thanks,
Jimmy
You'd be better off throwing those blocks.
You'd have to get all new bolts(should be grade 8), and lengthen your transfer case linkage, transmission linkage, make somthing to lift your fan shroud up, and hope it doesn't put your steering shaft it a bind, you'll need new shocks, plus you will see your frame and bumper hanging down, which I think is just ugly.
IF you'd do a suspension lift, then all you'd need for a 4" lift would be coils($115), c bushings($25), trac bar drop bracket($30), grade 8 bolts for a shackle flip in the rear($12ish), and if you want you could put a drop pitman arm($50)it isn't needed, but wouldn't hurt, and you could get some shock for about ($120-160).
Then you won't have the head ach of cutting and welding all kinds of extentions for the body lift, and you will have better flex off road, without the ugly look of the frame and bumper hanging down.
what do you mean by drop the front coil towers? do you mean unbolt the towers and lower them 2inches redrill new holes and bolt them back into place? Pleae let me know. Also how much work will it be to take the coils out and everythign to do so?
thanks,
Jimmy
Also doing the shackle flip does that make your rearend come closer to the front of the truck a little bit?
thanks again!
thanks,
Jimmy
thanks again!
It would be a hell of alot easier than doing a body lift. Besides, body lift should not even be an option, or even a thought. Basically, there are 2 bolts per side to get the spring out, two more per side to get the shock loose, then its just a matter of torching/drilling/grinding out the rivets that hold on the spring towers. Then measure up a few inches and drill the holes in the spring tower. As for the rear, just jack up the rear end, put it on stands, support the rear axle with a floor jack, remove the rear leaf spring bolt, torch/grind/drill the rivets out of the spring perch, flip it over, (you may have to drill a few holes here too), and bada boom, you just gained some inches of lift, without doing something stupid, like adding a body lift. Heck, if you live in the midwest, I'll do it for you, for a nominal fee, but you'll have to come to me. Heres a link of the exploded view of your front suspension http://broncograveyard.com/images/ca...SUSPENSION.JPG
wih the 3 inche suspention lift on the truck right no will the pinion angle still stay the same (as in will it still be ok) after i flip the shackels? also how far can i drop the spring towers? i gues i would wanna go 3 inch with them to match the back. also will i ned anyother parts to make it work?
thanks,
Jimmy
thanks,
Jimmy
79 f-150 guy
21
01-22-2016 12:05 PM
jonbass40
01-24-2009 08:48 PM
