Rookie mistake, how bad is it?
I have not checked to see if the engine is seized up. as soon as i hook up the batt you can watch it on the meter drop from 12.48 volts to 7 volts in a matter of a few secs. as soon as i disconnect the batt is slowly goes back up. i have pulled every fuse in the cab and took the radio out.
Your starter could just be bad from the incident, pull it, have it tested at Auto zone or somewhere else, usually no charge.
Take off the belt, or leave it on, put a 15/16" socket on a small extension with ratchet, on the nut for the flywheel, and see if the motor turns easily for you, should not require much effort. Lay down on the ground and reach up is easiest.
Didn't mean to copy cat timbersteel
well i was thinking the starter switch to but that was the first thing i replaced. i have followed every flipping wire from the starter switch to the end and everything looks fine. i also replaced the starter because that failed the bench test but my new one cant get enough juice. still will have the batt checked first chance i get. i will also try to check to see if its seized up. god i hope not.
ok here is where im at with this truck. there is a circler cluster of wires on the driver side of the fire wall. i disconnected it and put the batt fully chargered at 12.86 volts and it held. i unhooked the batt and hooked the cluster back up when i connected the batt once again it dropped to 7 volts. so i now think that its in the cab. i still kept all the fuses inside the cab out so it has to be something that has to be something that is hot all the time right? well i cant think of anything besides headlights and ignition switch. since the problem happens without the key in. i feel that im one step closer. please if you have any ideas help me. also on the other note the engine is not seized up. good news. i must have a short.
it drops without me even making it to the cab to try to crank it. as soon as i hook it up it drops but not when i unhook the wire cluster from the fire wall.
The batt is good i started another car with it. same problem with the other batt on my truck as well. could it be the voltage refulator. advance ran that by me.
Take apart that cluster of wires going to the positive side of the battery. one by one reinstall ONE wire only and see which wire has the most draw. Most likely you have other things fried from the battery being install backwards.
Better yet, pull out the battery and use a OHM meter with conitunuity and put the Neg side of the meter on the vehicle chassis ground, and then test each wire indvuidualy to see what is shorted. With key off you should NOT see any thing under 1K ohm.
I got a free truck from this exact issue! After replacing just about every electronic part, Got it running and made $$$ on it!
