Turning in 4wd
Turning in 4wd
New to my '03 this winter. I notice then when I have it in 4wd, when I turn the front wheels, it feels like they want to bind. The sharper the turn, the worse it feels. They lurch instead of turning smoothly. Works great in a straight line, but parking in a parking lot it's real bad. This is even on snow and ice.
Is this normal for these?
Yeah you don't want it in 4WD unless the wheels are slipping. This allows the system to keep from binding up.
Dry or even just wet pavement can lead to more wear and tear on the drive line and tires since each tire wants to turna different amount in turns.
When I expect bad weather, I will lock my hubs but keep the truck in 2WD. When I hit slippery conditions I will then put in 4WD, even on the move if the speed is low enough.
The lurch and binding is your truck saying "Don't do that" and is normal.
Good Luck,
Jim Henderson
Good Luck,
Jim Henderson
