Easy Oil Drain Valves
A guy at O'Reilly Auto told me that the origional Fram Sure Drain was recalled and Fram replaced it with a newer version. So the parts store chain decided not to carry that specific product in that brand anymore.
I bought a Dorman EZ Drain oil drain valve M14-1.50 (#092-007) for $10. As you might already know, it replaces the drain plug and is spring-loaded. Just push in orange **** and 1/4 turn to the right and it locks open, then push in and 1/4 turn to the left and it springs back for closed.
So far I am happy with the product. Dont see any leaks.
Anyone ever experienced this product? Good or bad results?
I've never heard of that drain plug. I believe most of us that use a "valve" type drain plug use a Fumoto valve (www.fumotovalve.com).
K . . .
Originally Posted by 2006PSDSD
I would be worried about vandalizim. Is there a way to lock the valve closed (so that some vandal can't open it)?
Very interesting valve. I would not have thought about draining the oil as a means of vandalism. I guess they would be targeting you specifically, and would bring a container to catch the oil, otherwise you would see all of the oil under the truck before you started the engine. But also, the oil light would light up once you started the engine. Nice world we live in.
This is what I did to secure the Fumoto valve, not against vandals, but it would work just as good against them. If they're willing to go through the trouble, and brought the tools to take off the clamp, then they could just as easily remove a stock drain plug.
How long have you had it on you truck? No problems? Where di you order your from?
Regarding the Fumoto valve, they come with a little lock clip that you insert around it, that's sort of a second security feature. To open the valve alone, you have to press the lever quite a bit forward, and then swing it down. It does take a bit of effort, so it's not like it will come open on its own. Then for extra piece of mind, there is the clip you can install onto it, or the hose clamp like EnviroCon uses works well, too.
Here's where I got mine from:
http://www.dieselsite.com/index.asp?...PROD&ProdID=33
U R Right . . .
The only way someone is going to do this, is someone who is out to get you for something you did. Just like sugar in the fuel tank was the rage in the 60's & 70's or a patatoe up the exhaust pipe.
It is an act of retribution vs vandals if it ever happens.
You know like catching somebody with your wife/girl in bed or something along those lines . . .
I would be worried about vandalizim. Is there a way to lock the valve closed (so that some vandal can't open it)? I know thats pretty far fetched, but there are a lot of creative punks out there that like to do things like that just to cause someone else greif.
Also my concern is that 'if something is too good to be true, it probably is'. This product makes oil changes more simple - as long as it works right and does not have a defect to it. The problem is that I am kind of paranoid now - always checking the dip stick & looking under my truck when I approach it. It is not worth loosing all my oil going down the road and costing me tons of $$$$ for a motor just for the oil changing convenience.
