Feasibility of never plugging in
Thinking about late model 7.3 or 6.0 to tow boat. It gets down to 20s, teens, and single digits often here in the winter. We occasionally go into single digit negatives. Does anyone not plug in thier trucks in this kind of environment? I just don't want to waste the electricity and I also have property that has no electricity to plug into.
Mike
Mike
Mike
Mike
JakeB sumed it up...
Switching to synthetic will solve 99% of your problems.. If you think you have any in those temps.
You have to have a different mindset with diesels as they require different care in the winter time then gas engines do. If you have the opportunity to plug the block heater in an hour or two before you start it will make a huge difference. You don't have to leave it plugged in all night and waste all of the electricity.
FWIW I haven't had mine plugged in for a month and half... I run synthetic and haven't had any issues. Just make sure your glow plug system is functional.
My block heater quit working 2 weeks ago. It has been down to below 0 several times since then. She never hesitates to start. I still run dino oil.
To save on electricity, buy a heavy duty timer. Turn your heater on 3 hours before you have to start the truck.
For the location without electricity, consider a small generator. The heater is only 1000 watts.
on
I have never once plugged in any of my diesels and I've only owned diesel trucks up until the 150 that I have now along with my 6.0.
Both places that I live see the same type of winter that you just described. Out of the trucks that I've owned, I've only had to replace 1 FICM during the winter that was giving me a performance code. It never failed to start, but it was getting iffy. That FICM lasted 5 yrs and up until then I never kept a vehicle that long(and I still have it). I do run synthetic on that truck though, but that is the only one that I have done so.
Received 3,108 Likes
on
I agree.. Synthetic helps alot! Plugging in may not always be "necessary", but hey, if a person can help wear and tear, or strain, I am all for extending the life of mine!
You may have better luck with this one in a different forum. But I would try a dealer if it were me.
Welcome!
You should start a new thread for this. But, the info you are looking for is in the "TECH" folder at the top of the 6.0 page. The "Tech" folder has alot of info for your truck.
Since you are here:
https://www.ford-trucks.com/forums/8...icle-post.html
Mike
Mike
