Toyota power steering leak
I bought a complete toyota power steering setup from Mid-Fifty for my 55, & I cannot keep the return line fitting from leaking at the steering box end. I have tried teflon. Anyone else have this promblem? Remedies? I have talked with Mid-Fifty and they said they have had some complaints about this fitting & they're checking into it. Can I go to the local Toyota dealer and buy this hose? The pump end of the hose just attaches to the pump with a hose clamp. THANKS
You need to figure out what type of fitting you have, and what the box needs. I have never worked on a Toyota box, but I can list a few of the fitting types you may encounter. First there is pipe threads, which are tapered threads and require the teflon tape. I have never seen these used on a power steering box. Then there is the flare type fitting. The nut has straight threads, and it's only job is to push the tubing against the tapered seat down in the steering box fitting. If you have this type of fitting, check the condition of the seat and see if it is damaged, which would cause a leak. The other type of fitting I have encountered is the o-ring type. Again, the nut has straight threads and it's only job is to hold the tubing and o-ring in place.
Thanks for the input Franklin. It appears to me that the return hose fitting is a flare-type fitting, but the box looks like pipe threads with no tapered seat. I have tried teflon, but it didn't help. The flare-type fitting is snugging down tight to the box and no seat to seal against. I don't understand this, because I bought all the hoses & box as a complete kit from Mid-Fifty. Wouldn't you think they would no if it was wrong. As I posted previously, could I go to the local dealer and get the correct hose & fitting, or is there a fitting that would fit into the box for my flare-fitting to seat against. THANKS
I bought a junkyard box and at first didn't have that return fitting. It is not the same thread as the supply side. It is a wierd thread, I had to get the return fitting from a different junkyard, I think it fits most Toyota truck PS boxes in the late 70s-80s. You would think they would send the correct fitting, but from my research it is not a standard item. I couldn't buy a return hose with a fitting from any parts store I checked, they just listed bulk hose. Hope that helps. PS, I have had no leaks either.
