The motor doesnt have to be removed...but the old exhaust header does, if you can find one at a local junk yard, and if its in good condition, then go for it. You do however have to get a set of exhaust gaskets and presoaked the exhaust bolts (WD-40 or other rust bustin fluid) Retorqued the bolts in the correct pattern and reconnect the air tubes.
