wiring diagram for lincoln column?
Old 04-01-2002, 04:06 PM
jaye's Avatar
jaye
jaye is offline
Old 04-02-2002, 11:29 AM
hirschi's Avatar
hirschi
hirschi is offline
Anyone know how I can get a wiring diagram for the plug on a 65 Lincoln steering column. I'm trying to install it in my 59. I bought an EZ-wiring kit and it only comes with the GM plugs. Thanks for any help I can get.
James
Old 04-02-2002, 12:24 PM
jaye's Avatar
jaye
jaye is offline
Check your local library or go to a major book store they have manuals. Here is a standard ford column, if it doesn't work find the hot wire usually red and use a test light to find the right wires.
brake light switch green
L-rear turn signal green/orange
L-front turn signal green/white
emergency flasher white.red
R-front turn signal white/blue
L-front turn signal orange/blue
battery yellow
Acc gray
coil white or red/green
solenoid brown or brown/purple
Acc black or black/green
I hope this helps this is from Kwik wire, you can also go to painless wire web site and download instructions
Jaye
Old 04-02-2002, 01:16 PM
55FordLover's Avatar
55FordLover
55FordLover is offline
I like to thank you too...I just bought a used 77 Ford Van column and have the ezwiring harness too....that should help me out a lot..
James
55 Ford 223/3spd (for sale)
54 Ford 302/AOD Soon :-)
Old 04-04-2002, 03:25 PM
hirschi's Avatar
hirschi
hirschi is offline
Thanks for the info. Jaye.
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: wiring diagram for lincoln column?
