Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #136 (permalink)
Old 05-16-2008, 09:11 AM
roger dowty is gaining momentum as a positive member of FTE.roger dowty is gaining momentum as a positive member of FTE.
good to see your on it again...looks like someone lost a trailer with that reciever eh?
in the second to last pic theres a jagged edge where the rough black meets rust bullet...wondering what that is?
thanks...just getting back to my projects as well.
__________________
'77F1504x4, '75 f250crew4x4, '79 Bronco 429, '83 bronco, '72 Torino with 351cj, 70 1/2 falcon, 75 stangII. all projects, 2 on the road. One pissed off wife!
  #137 (permalink)
Old 05-16-2008, 11:33 AM
cje07's Avatar
cje07 is starting off with a positive reputation.
Yeah Roger! You mean in this picture?
The line that seperates the Rough Black Durabak and the Rust Bullet is where the slip on Rocker panels will be glued in. Once they are in place, I'll spray with a final coat to get everything to seal up good and tight. The Rockers look like this:
__________________
1986 Ford Bronco XLT[
302 EFI, manual 4 speed
K&N, 3G Alt, MK Classic II's
Accel Supercoil
Ford 8mm Wires
MSD Cap/Rotor
Equus Mechanical Gagues
Edelbrock Shocks
Rancho lift
The Video: http://www.supermotors.net/vehicles...ry/media/619611
WARNING: Restoration in progress!!!
  #138 (permalink)
Old 05-16-2008, 11:42 AM
cje07's Avatar
By the way...
I got the hitch, access cover and underside of the rockers lined the other day. I hope to put the hitch back on and snap some pictures. Soon I am hoping to take the top off, test fit, and start gluing the rear fenders on as well as the rockers. I was hoping to do some this weekend, but my wife has plans for a garage sale! UGH
Yes Roger...that hitch has seen some abuse prior to me owning it. I drilled some new holes further up on that plate and put in some heavy duty D-rings for the trailer chains. Should do the trick!
__________________
Accel Supercoil
Ford 8mm Wires
MSD Cap/Rotor
Edelbrock Shocks
Rancho lift
  #139 (permalink)
Old 05-17-2008, 08:24 AM
cje07's Avatar
Final Hitch pics...
So I got a chance to put the hitch on last night...WOW...it really turned out nice! It's these little things that will make the final product look really good...what sense does it make to have the entire body look good only to have a rusty/crusty hitch...enjoy!
If you look in the back of the truck you can see the finished tailgate access panel. I'll try to snap some pictures of what the underside of the rockers look like. I plan on a few more coats though when I put a final coat on the top.
__________________
Accel Supercoil
Ford 8mm Wires
MSD Cap/Rotor
Edelbrock Shocks
Rancho lift
  #140 (permalink)
Old 05-18-2008, 11:41 AM
Heavenword1 is starting off with a positive reputation.
Question
Dumb question. Can the Durabak be painted? I know it comes in X number of colors, but my son wants to have a camo truck. But it sure would be nice to have Duraback surface underneath.
  #141 (permalink)
Old 05-19-2008, 06:43 AM
cje07's Avatar
camo
Nope! I think there is a guy who did a camo job with the durabak colors though. You might want to check out durabakcompany.com. Also check out the color chart Cote-L Distribution Company
__________________
Accel Supercoil
Ford 8mm Wires
MSD Cap/Rotor
Edelbrock Shocks
Rancho lift
  #142 (permalink)
Old 05-23-2008, 04:45 PM
cje07's Avatar
Made real progress today!
Hey everyone...I made some real progress today. I was only supposed to have a 1/2 day off but the bossman let me take the entire day off. Good thing!. First thing I planned on doing was glueing those slip on rockers in. But in order do that, I needed to test fit the rear fenders, determine if there where any gaps as well as any other hacking.
A good friend of mine came over to help me lift the top off as well as take off and fit the fenders multiple times. Thanks Joe A., would'nt have been able to do it without you. Also, big thanks to Sixlitre for his insight and suggestions.
Here is the result...feel free to ask any questions! By the way...I only had enough glue for the rockers and had to order some more. I'd rather fit, and refit the rears as much as possible to get these things hung right.
Drivers Side:
Passenger Side:
This is an area I was really worried about lining up and having gaps. After some trimming and fitting I finally got them to fit nicely. Although they will still need some seem sealer!
__________________
Accel Supercoil
Ford 8mm Wires
MSD Cap/Rotor
Edelbrock Shocks
Rancho lift
  #143 (permalink)
Old 05-23-2008, 08:50 PM
ibleedblue1385's Avatar
ibleedblue1385 has a good reputation on FTE.ibleedblue1385 has a good reputation on FTE.ibleedblue1385 has a good reputation on FTE.
just tuning in to see this. that is going to sweet when its done!!!
__________________
-Jesse ~Built Not Bought~
STGs Minions - The Project Specialist
1986 F150 4x4/5.0/SAS/C6/208/9"
1988 F150 4x4/5.0
1977 F250 4x4/351M/C6/205 "Hell"
Michigan Chapter Member
  #144 (permalink)
Old 05-24-2008, 07:00 AM
cje07's Avatar
Just getting those sides on is one huge step for mankind...ok...just me then! It really does make a huge difference once you get this far. Just waiting for glue on Tuesday to get them permanently hung on. Thanks IBLEEDBLUE!
__________________
Accel Supercoil
Ford 8mm Wires
MSD Cap/Rotor
Edelbrock Shocks
Rancho lift
  #145 (permalink)
Old 06-08-2008, 09:19 PM
cje07's Avatar
Huge progress made!
Finally got the other tube of glue over the week and some extra tips.
TIP #1 If you do this project do yourself a favor and get extra tips! Otherwise you will end up wasting glue. If you let the gun sit for too long...2-3 minutes the glue will clog the tip. If you try to "push" the gun it will cause the tube to leak out the backside.
Glue = $27.oo a tube
Tips = $0.42
TIP#2 Have a good friend available to help with the gluing process. It is good to have someone help you hold, slide and clamp the fenders in place.
TIP#3 Buy/borrow yourself plenty of clamps. I think I had 25-30 clamps available to hold down specific glue points
TIP#4 Make sure to fit and refit many times until you are happy how everything lines up. I actually fit, clamped, put the top on many times until I was happy with the fit. Also took measurements at key points to make sure both sides were lined up at the correct heights. Must have done this at least 3-4 times.
TIP#5 once I was happy with the fit I drilled pilot holes for rivets...these would serve 2-purposes...alignment and hold until the glue sets up. Afterward the heads can be ground off sanded, seam sealed and painted.
The steps are easy...
Step #1 I glued the bed rail and the inner tailgate rails located on the truck. I then placed glue on the lip of the fender located at the b-pillar as well as the tabs located by the rocker panels. I had twenty minutes until the glue set to make adjustments.
Step #2 - slide the fender into place,set it, rivet and clamp.
Fill the seam with glue:
This will need to be sanded and filled with seam sealer:
SOME of the clamps:
Clamp the insides of the taillights:
Step#3 - pat yourself on the back...you've glued your first fender...hurry up and do the other side.
Here are a few pics of the test fit; it gives you a whole lot better look of what the final product will look like:
If you have questions, post up! This is truly the most time intensive as far as planning and preparing to get these babies glued. Think through or write down your process steps before you start this section...it really does help! Of course this thread should also help you as well!
__________________
Accel Supercoil
Ford 8mm Wires
MSD Cap/Rotor
Edelbrock Shocks
Rancho lift
  #146 (permalink)
Old 06-08-2008, 10:38 PM
khadma's Avatar
<I really look like this
khadma has a great reputation on FTE.khadma has a great reputation on FTE.khadma has a great reputation on FTE.khadma has a great reputation on FTE.khadma has a great reputation on FTE.
I like the way it is turning out. I remember this thread from a while back and it looks great.
I have to look back at what you used as the finish coat for the body. I have an 84 Bronco waiting to get worked on after I finish my Ranger project.
Keep up the great work and keep us posted with more pictures.
__________________
1996 Bronco xlt 5.8,a/t,a/c,31x10.5 BFG's A/T
1999 Ranger supercab xlt 3.0, a/t
1984 Bronco 4.9l, 4spd manual
2002 F150 regular cab shortbox XL 4.2 a/t
1995 Windstar
2007 Explorer XLT 4.0 a/t
1988 Mazda B2200
Member of the Hawai'i Carpenters Union - Local 745
Darren
  #147 (permalink)
Old 06-13-2008, 11:23 AM
cje07's Avatar
Thanks Khadma! Yeah this thing has come along way! I'm getting off work early today to do yet another upgrade. I think I have Bronco ADHD! When my wife and kids asked what I wanted for Father's Day I asked for a coolant fan upgrade. Taking an Electric Cooling Fan out of a 95 Ford Taurus and putting it into the Bronco (getting rid of the mechanical fan). There have been claimed gas savings of 2mpg and an increase performance of 16hp. I'll do a seperate thread write up on this if you guys are interested! I also plan on getting a little work done on the body too today. We'll see how it progresses!
Peace!
__________________
Accel Supercoil
Ford 8mm Wires
MSD Cap/Rotor
Edelbrock Shocks
Rancho lift
  #148 (permalink)
Old 06-13-2008, 11:27 AM
dragogt's Avatar
dragogt has a very good reputation on FTE.dragogt has a very good reputation on FTE.dragogt has a very good reputation on FTE.dragogt has a very good reputation on FTE.
Definitely, please do a write up on the E- fan upgrade.
__________________
87 F150 lwb
83 bronco
86 mustang gt t-top
83 mustang gt
Aaron - - Pirate Investigator
FREE STG.
Quote:
Originally Posted by STGFordCrazy04 View Post
what? someone actually broke a TTB?
Im fabbergasted!
these tires bring the epic suck!
They are thornbird wanna-bes! Which is quite possibly the most derogitory thing someone could say about a tire sold for offroad purposes.
  #149 (permalink)
Old 06-13-2008, 09:43 PM
72f250CS's Avatar
72f250CS is starting off with a positive reputation.
Man that's looking great, I am so jealous..
__________________
What do you mean the suspensions bad?
BRENT KALIE DAD
85 Bronco 351W 4x4--the new kid
72 F250 CSSC FE390 C6 2wd-- Sold
58 VW Baja---gone away, bye bye
No man stands as tall,
as when he kneels to help a child.
  #150 (permalink)
Old 06-14-2008, 02:42 PM
cje07's Avatar
06/14/2008
Quote:
Thanks man!
To all...I started the E-Fan write up, but won't post it until I am done. Just got a wirelss back-up camera from the family for Father's Day too. I temporarily rigged it up today and it works GREAT! Can't wait until the truck is finished. I wanted this thing so I would'nt back-over one of my kids or smallish Honda's (I've done it...Can't believe I did'nt see that thing...and I even had the top off!)
Well I am of for a week to be a counselor at Kid's Camp. When I get back I plan on taking a full day to do some more damage!
__________________
Accel Supercoil
Ford 8mm Wires
MSD Cap/Rotor
Edelbrock Shocks
Rancho lift
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
