1978 - 1996 Big Bronco
1986 FSB Restoration Project (56K Warning)
  #136
Old 05-16-2008, 09:11 AM
roger dowty's Avatar
roger dowty
roger dowty is offline
good to see your on it again...looks like someone lost a trailer with that reciever eh?
in the second to last pic theres a jagged edge where the rough black meets rust bullet...wondering what that is?
thanks...just getting back to my projects as well.
  #137
Old 05-16-2008, 11:33 AM
cje07's Avatar
cje07
cje07 is offline
Yeah Roger! You mean in this picture?
The line that seperates the Rough Black Durabak and the Rust Bullet is where the slip on Rocker panels will be glued in. Once they are in place, I'll spray with a final coat to get everything to seal up good and tight. The Rockers look like this:
  #138
Old 05-16-2008, 11:42 AM
cje07's Avatar
cje07
cje07 is offline
By the way...
I got the hitch, access cover and underside of the rockers lined the other day. I hope to put the hitch back on and snap some pictures. Soon I am hoping to take the top off, test fit, and start gluing the rear fenders on as well as the rockers. I was hoping to do some this weekend, but my wife has plans for a garage sale! UGH
Yes Roger...that hitch has seen some abuse prior to me owning it. I drilled some new holes further up on that plate and put in some heavy duty D-rings for the trailer chains. Should do the trick!
  #139
Old 05-17-2008, 08:24 AM
cje07's Avatar
cje07
cje07 is offline
Final Hitch pics...
So I got a chance to put the hitch on last night...WOW...it really turned out nice! It's these little things that will make the final product look really good...what sense does it make to have the entire body look good only to have a rusty/crusty hitch...enjoy!
If you look in the back of the truck you can see the finished tailgate access panel. I'll try to snap some pictures of what the underside of the rockers look like. I plan on a few more coats though when I put a final coat on the top.
  #140
Old 05-18-2008, 11:41 AM
Heavenword1's Avatar
Heavenword1
Heavenword1 is offline
Question
Dumb question. Can the Durabak be painted? I know it comes in X number of colors, but my son wants to have a camo truck. But it sure would be nice to have Duraback surface underneath.
  #141
Old 05-19-2008, 06:43 AM
cje07's Avatar
cje07
cje07 is offline
camo
Nope! I think there is a guy who did a camo job with the durabak colors though. You might want to check out durabakcompany.com. Also check out the color chart Cote-L Distribution Company
  #142
Old 05-23-2008, 04:45 PM
cje07's Avatar
cje07
cje07 is offline
Made real progress today!
Hey everyone...I made some real progress today. I was only supposed to have a 1/2 day off but the bossman let me take the entire day off. Good thing!. First thing I planned on doing was glueing those slip on rockers in. But in order do that, I needed to test fit the rear fenders, determine if there where any gaps as well as any other hacking.
A good friend of mine came over to help me lift the top off as well as take off and fit the fenders multiple times. Thanks Joe A., would'nt have been able to do it without you. Also, big thanks to Sixlitre for his insight and suggestions.
Here is the result...feel free to ask any questions! By the way...I only had enough glue for the rockers and had to order some more. I'd rather fit, and refit the rears as much as possible to get these things hung right.
Drivers Side:
Passenger Side:
This is an area I was really worried about lining up and having gaps. After some trimming and fitting I finally got them to fit nicely. Although they will still need some seem sealer!
  #143
Old 05-23-2008, 08:50 PM
ibleedblue1385's Avatar
ibleedblue1385
ibleedblue1385 is offline
just tuning in to see this. that is going to sweet when its done!!!
  #144
Old 05-24-2008, 07:00 AM
cje07's Avatar
cje07
cje07 is offline
Just getting those sides on is one huge step for mankind...ok...just me then! It really does make a huge difference once you get this far. Just waiting for glue on Tuesday to get them permanently hung on. Thanks IBLEEDBLUE!
  #145
Old 06-08-2008, 09:19 PM
cje07's Avatar
cje07
cje07 is offline
Huge progress made!
Finally got the other tube of glue over the week and some extra tips.
TIP #1 If you do this project do yourself a favor and get extra tips! Otherwise you will end up wasting glue. If you let the gun sit for too long...2-3 minutes the glue will clog the tip. If you try to "push" the gun it will cause the tube to leak out the backside.
Glue = $27.oo a tube
Tips = $0.42
TIP#2 Have a good friend available to help with the gluing process. It is good to have someone help you hold, slide and clamp the fenders in place.
TIP#3 Buy/borrow yourself plenty of clamps. I think I had 25-30 clamps available to hold down specific glue points
TIP#4 Make sure to fit and refit many times until you are happy how everything lines up. I actually fit, clamped, put the top on many times until I was happy with the fit. Also took measurements at key points to make sure both sides were lined up at the correct heights. Must have done this at least 3-4 times.
TIP#5 once I was happy with the fit I drilled pilot holes for rivets...these would serve 2-purposes...alignment and hold until the glue sets up. Afterward the heads can be ground off sanded, seam sealed and painted.
The steps are easy...
Step #1 I glued the bed rail and the inner tailgate rails located on the truck. I then placed glue on the lip of the fender located at the b-pillar as well as the tabs located by the rocker panels. I had twenty minutes until the glue set to make adjustments.
Step #2 - slide the fender into place,set it, rivet and clamp.
Fill the seam with glue:
This will need to be sanded and filled with seam sealer:
SOME of the clamps:
Clamp the insides of the taillights:
Step#3 - pat yourself on the back...you've glued your first fender...hurry up and do the other side.
Here are a few pics of the test fit; it gives you a whole lot better look of what the final product will look like:
If you have questions, post up! This is truly the most time intensive as far as planning and preparing to get these babies glued. Think through or write down your process steps before you start this section...it really does help! Of course this thread should also help you as well!
  #146
Old 06-08-2008, 10:38 PM
khadma's Avatar
khadma
khadma is offline
Carpenter Local 745
I like the way it is turning out. I remember this thread from a while back and it looks great.
I have to look back at what you used as the finish coat for the body. I have an 84 Bronco waiting to get worked on after I finish my Ranger project.
Keep up the great work and keep us posted with more pictures.
  #147
Old 06-13-2008, 11:23 AM
cje07's Avatar
cje07
cje07 is offline
Thanks Khadma! Yeah this thing has come along way! I'm getting off work early today to do yet another upgrade. I think I have Bronco ADHD! When my wife and kids asked what I wanted for Father's Day I asked for a coolant fan upgrade. Taking an Electric Cooling Fan out of a 95 Ford Taurus and putting it into the Bronco (getting rid of the mechanical fan). There have been claimed gas savings of 2mpg and an increase performance of 16hp. I'll do a seperate thread write up on this if you guys are interested! I also plan on getting a little work done on the body too today. We'll see how it progresses!
Peace!
  #148
Old 06-13-2008, 11:27 AM
dragogt's Avatar
dragogt
dragogt is offline
Definitely, please do a write up on the E- fan upgrade.
  #149
Old 06-13-2008, 09:43 PM
72f250CS's Avatar
72f250CS
72f250CS is offline
Man that's looking great, I am so jealous..
  #150
Old 06-14-2008, 02:42 PM
cje07's Avatar
cje07
cje07 is offline
06/14/2008
Thanks man!
To all...I started the E-Fan write up, but won't post it until I am done. Just got a wirelss back-up camera from the family for Father's Day too. I temporarily rigged it up today and it works GREAT! Can't wait until the truck is finished. I wanted this thing so I would'nt back-over one of my kids or smallish Honda's (I've done it...Can't believe I did'nt see that thing...and I even had the top off!)
Well I am of for a week to be a counselor at Kid's Camp. When I get back I plan on taking a full day to do some more damage!
Quick Reply: 1986 FSB Restoration Project (56K Warning)
