Transmission cooler........
I am assuming you are rebuilding or replacing the transmission?
The best method to flush the cooler you can take the lines off the transmission and use a can of "cooler flush". This is a commercially available product that is an aerosol can with a nozel that fits the cooler lines. You then spray the can of flush through the lines and blow it out with compressed air. Works fine.
Or, you can slip a rubber hose over one of the lines long enough to reach up above the engine cover and poor some mineral spirits through it. Then blow that out with compressed air.
Steve
'95 Clubwagon XLT
Steve
'95 Clubwagon XLT
2006powerstroke90
09-07-2014 11:33 AM
