I am going to be converting my '91 4.9L (300) six from E4OD to ZF 5-speed pretty soon. I have 2 flywheels, one from a 351 and one from a 302. Can I use one or either of these on my 300?
OK, thanks for the info (impressive knowledge with the weights, KB). I will need to seek out a 300-specific flywheel then. Followup question: If I am looking at one that I am told is for a 300, will it have no weights on the back whereas the 351 and 302 will?
You can hunt down the specific flywheel you need, or any any machine shop rebalance the 302/351 flywheels to zero. It's an easy job actually.
Just make sure the 302/351 flywheels fit nicely and line up on the 300 crank snout, otherwise its a waste of machine work. Though, the machine shop can weld the holes closed and redrill. I've done that before. That's a PITA but it does work just dandy.
