Anyone Have Any Experience With This Engine Jumping Time?
I Am Wondering If It Bends Valves,can You Get Away With Replacing Chain, Guides And Tensioner. Or Should I Start Looking For A Used Engine.
Yhanks For Your Help, Tim
If it jumps one tooth you should be fine. Any more than that and it probably bent the valves. To check take both rocker arms off and put compressed air in the cyl. If air comes out the intake or exhaust the valve is bent.
I Am Pretty Sure The Engine Is Toast Has No Compression In Any Cylinder.found Out The Owner Was Revving It Up Cold Because It Would Stall Cold When It Happened. Probably Would Have Been A Lot Cheaper To Fix The Stalling Problem.
Yhanks For The Info Tim
