Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Main Computer Location
Old 05-19-2003, 03:59 PM
lightninglowe's Avatar
lightninglowe
lightninglowe is offline
i bought a downs computer for the mass air conversion off of ebay and it doesnt have the instructions....can anyone point me in the right direction..
Old 05-19-2003, 07:04 PM
ecarter50's Avatar
ecarter50
ecarter50 is offline
Have you tried contacting Downs Ford?
http://www.downsford.com/contactus.htm
Old 05-19-2003, 07:48 PM
stangdawg24's Avatar
stangdawg24
stangdawg24 is offline
was your truck mass air before you got it or was it speed density???
Old 05-19-2003, 10:07 PM
lightninglowe
it was speed density...i just need to know where is the main computer that im changin...
Old 05-19-2003, 11:41 PM
ecarter50's Avatar
ecarter50
Sorry I misunderstood what you were asking. The computer is behind the plastic panel by the emergency brake. I have read the easiest way to change it is to loosen the drivers side fender/inner fender.
Old 12-03-2006, 09:18 PM
Milwaukee's Avatar
Milwaukee
Milwaukee is offline
It is behind your emergency brake.remove it and it is in there.
Old 12-03-2006, 11:52 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
The ECU cannot be removed from inside the cab, it can be accessed/removed from inside the engine bay though.
Open the hood and look below and to the right of the master cylinder/brake booster and you will see the main harness. Loosen the main harness bolt (it's metric) and remove the harness from the ECU. There are also two nuts, and a rubber retainer, that hold the ECU in place (they're metric as well), remove the nuts and retainer. You will also have to remove some of the screws for the inner fender well so the ECU can slide out. Once you remove the nuts and screws, push down and away on the fender well and remove the ECU; it'll take a little work, but it's not hard and it doesn't take long at all.
Old 12-04-2006, 01:32 PM
Milwaukee's Avatar
Milwaukee
Unhappy
Ya he is right. I was just thinking when I put a chip in my old 95 f250.
old fool
Aerostar
02-11-2006 07:41 PM
Ultramagdan
1983 - 2012 Ranger & B-Series
07-26-2002 12:12 PM
MustangGT221
02-03-2002 02:33 PM
bgodkin
01-31-2001 10:22 AM
jimp
Computer Chips & Tuners
12-29-2000 06:03 PM
Quick Reply: Main Computer Location
