Tortion bars
Old 11-09-2006, 04:06 PM
Duec66's Avatar
Duec66
Duec66 is offline
Tortion bars
What are the pros and cons of tweaking my tortion bars to fit a bigger tire. I have an 02 F-150 Supercrew 4X4. Thanks
Old 11-09-2006, 04:07 PM
Duec66's Avatar
Duec66
Duec66 is offline
Before I get flogged, I tryed to search but it wont let me.
Old 11-09-2006, 04:49 PM
GammaDriver's Avatar
GammaDriver
GammaDriver is offline
Pros: you can even-out suspension that has sagged at different rates; you can add height, and ... ???
Cons: you can over-heighten them, causing an alignment issue not easily fixed; you could, I suppose, make the sides more uneven if you were a goof; you can approach a limit of your shock-absorbers' range so that they won't allow the a-arm to go down any more in repsonse to a hole/drop-off; and I guess you could make a truck less aerodynamic if the front end was too high compared to the rear.
Old 11-09-2006, 04:55 PM
Duec66's Avatar
Duec66
Duec66 is offline
I would deffinately have an alignment shop do the tweaking and tire instalation.
jrlowscot's Avatar
jrlowscot
jrlowscot is offline
Con: It can put more pressure on your front CV Axles causing premature wear/ failure
Pro: Your truck will not look like it's heading downhill all the time
Old 11-09-2006, 09:10 PM
97Handshaker's Avatar
97Handshaker
97Handshaker is offline
As long as you dont crank them over 1.5-2 inches you should be ok.
