'56 front wheel hub
Here's a few links to try, the first two show a hub.
What's wrong with yours?
http://www.bobsf100.com/CatPg27.html
http://www.parts123.com/parts123/yb.dll?parta~partsort
http://www.yourkansasconnection.net/
http://www.greensalescompany.com/
good luck
Bobby
good luck
Bobby
Are you are talking about the spindle being worn from a bearing spinning? Pics would be helpful.
Take a center punch and make a series of indentions around the spindle. That in effect raises small areas of the spindle. Check your bearing against it to see how tight it fits. You may need to use sand same paper to smooth it a little. For a cheap quick fix, it works.
Then when you can afford a better one, go get one. Than again...my ranger (my brothers now) has had one spindle done this way for around 10 years now.
EDIT: Maybe ***** got me confused...Your talking about a brake drum? OOPS.
Originally Posted by Nuthin
No, the hub is out of round. The spindle is fine, the drum is fine. I have no idea how it got that way as it's been a problem as long as I've owned the truck. I want to replace it if I can while we're doing everything else.
How are you determining its out of round? Just looking at the outer edge of it by the outer wheel bearing is not a good indicator as these are cast pieces that have had the bearing seats machines out of them. Basically, the hub might be turning true but look out of round due to slight variations in the outer surface.
If it looks like its out of round because the drum is wobbling it could be that the drum is not seated properly due to rust or crud, etc
I think the best way to test it would be to remove the drum from the hub and give it a good spin, you could use a dial indicator to measure the run-out of the surface taht back the brake drum.
Good luck
Bobby
Good luck
Bobby
Good luck
Bobby
If you can find someone here that has made a disk conversion that used a replacement hub or has put in a IFS and still has their beam axle around they might still have their original hubs. Mid Fifty keeps some parts vehicles around and do sell used parts if they have them. They show every part BUT the hub available in their catalog.
