Looking at the front fenders I think the opening is slightly to big. Would it be possible to use F-1 front lower panels and bend the opening to fit. It looks like it would bolt in.
They wouldn't really just bolt on. The back edge where the 2 meet and angle down are not the same. EMS was producing them at one time. I'd check with them before you alter a F-1 set.
The upper half is actually shorter by that junction because of the wheel opening radius. You would have to add to that area of the upper half to meet the F-1 lower section. The F-1 section would stick into the wheel opening towards the tire. i'd try to find some that are good or at least repairable. Seems like alot of work to modify.
