Code help!!
Code help!!
Had a friend drive by and stop while I was checking my transmission level. Trans doesn't shift right when it gets all warmed up. It drives OK when its cool. While the engine was still cool it showed high on the hot side of the stick. I'm thinking the tranny shop who worked on it last year over filled it.
Anyways the friend that stopped by had a Super Tuner tool for his Ford truck that fit my year truck and he hooked it up just for a quick diagnostic check and showed a code P0603 and looked it up in his manual and said it was a Ctrl mod KAM error. The star listed next to the P0603 showed it as a Computer and auxillary output catagory.
Any ideas????????
97F250 7.3L auto trans
Any ideas????????
Thanks again for the replies.Yes I did disconnect my batteries just last Friday to check the condition of my batteries and to clean all the posts and connectors, cause its been sitting with a trickle charger on it. (Been driving my new car) I'm hoping too much oil is the only problem and I've not added any myself. Its been over a year since the rebuild and what a nightmare that was with them. It took almost a month for them to get it back to me and had to redo it three times. Once it was for a cracked case which I think they did and they didn't charge me for it. I will not take it back to them thats for sure. But now I will take it to someone to check then change the oil and filter and hope fully they can run a sensor check on the tranny.
