Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-26-2006, 09:49 PM
ksmith203's Avatar
ksmith203 ksmith203 is offline
Garage is empty, add now
ksmith203 is gaining momentum as a positive member of FTE.
Smile 8RT engine parts available
I went to check on my 8RT block which was being magnifluxed at the engine shop. The block was cracked so its junk. I still have all the parts that came off the engine. If anyone needs any of these parts pm me and we will make arrangements to get the m to you. I don't want to throw them in a dumpster if someone else can use them. I can be reached at 330.353.0605. I live in Massillon Ohio about 55 miles south of Cleveland. Hopefully these parts can help someone out. I was upset because this is my second flathead I tore apart. Now I tore a flat 6 a 7HA motor apart. It will be magnifluxed tomorrow.
  #2 (permalink)
Old 10-27-2006, 10:11 AM
soule46 soule46 is offline
soule46 is starting off with a positive reputation.
Too bad you are so far away. I could use the water pumps, so that I have something to rebuild. I could also use some valves and guides. Bummer.
  #3 (permalink)
Old 11-06-2006, 09:21 AM
SteV8e's Avatar
SteV8e SteV8e is offline
SteV8e is starting off with a positive reputation.
Most flathead blocks are cracked. Did you investigate repair? I've seen threads on this forum regarding evaluating a crack's repairability (can you see both ends of the crack?). I've heard tell of a shop that was selling blocks (with repairable cracks) that they were scrapping for customers. Some have said that the cracks are latent features in these flathead blocks.
__________________
SteV8e
1952 F3
Put this in your signature if you are a Christian with an Effie!
Tags
8rt, engine, flathead, ford, list, motoir, parts, pumps, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
