Colorado Chapter Join Chapter, Leader:
Best Front clip for 48 F-1
Old 10-31-2006, 08:05 PM
48 Steel's Avatar
48 Steel
48 Steel is offline
Question Best Front clip for 48 F-1
I just picked up a new project and am trying to decide on what I should put under the front end of the 48 F-1 Street Rod truck?
Old 11-01-2006, 08:55 PM
jrzoffroad's Avatar
jrzoffroad
jrzoffroad is online now
I have always thought the old Mustang II stuff worked pretty well. You can buy kits that weld up to your exisitng frame using Mustang II front end parts. Some Mustang II's came with 302's and 5 lug front wheels. Although I believe that you can get rotors drilled with any pattern you like. You may have already though about this, but I think the airbags are the way to go for the suspension. I have always stayed away form the volaire and camaro stuff as it isn't ford stuff and I am not a big fan of chopping a frame into two pieces and then welding it back together. Should be a fun project.
doubledoyle
15
04-14-2017 11:59 AM
flatheadjohn
08-26-2016 12:40 PM
hbixby
12-04-2009 06:08 AM
midcal48
11-10-2009 04:18 PM
Quick Reply: Best Front clip for 48 F-1
