I have to replace my injectors on my ´94 b3000 (3.0v6). I need to know what the stock pressure is and would it maike any sense to use a higher pressure injector or not? and if so what pressure rating ? Thanx
IIRC, it is 30-45psi. It would make no sense to have higher pressure as it would add more fuel than can be burnt effectively, (if the ECM couldn't compensate for the extra fuel.)
tom
