Will '70 F350 Disc Brakes work on my 72 F250?
I've got a 72 F250 camper special that has power disc brakes, but the truck has been sitting for a while. I have the complete front end from a 70 F350 with disc brakes. Will the complete ibeams from the F350 swap over to the F250? Also, I know both are 8 lug, but is there any chance that my original F250 16.5 rims won't work. I want my F250 to look original.
thanks
Austin
thanks
Austin
thanks guys. I haven't decided what I'm going to do. The F350 was a 4 wheel truck (not 4WD). I don't know if I'm just going to move over the Ibeam/radius arm combo from the F350 to the F250 or just rebuild what the F250 has. I think I'm going to swap the F350 brakes over. That would be the least exspensive thing to do.
thanks
Austin
thanks
Austin
sorry John,
maybe I wasn't clear. Both the F250 CS and the F350 have disc brakes. So its a wash as far as that is concerned. The disc brakes from the F350 have been rebuilt and look great. The disc brakes on the F250 CS have been sitting for a long, long time. Unless that is some problem I don't know about, I'm going to take the twp ibeam/radius arm/spindle/disc brakes assy from the F350, put on new radius arm bushings and ibeam bushings and put them on the F250 CS. That way, the only thing I'm out is the rubber bushings.
thanks
Austin
thanks
Austin
John,
The only reason I was considering this is I thought the factory disc brakes on the 72 F250 CS might be expensive. The CS hasn't moved since 79 so needless to say, some bits need replacing. I have rebuilt the 360 and C6, and I'm detailing it now. I'm completely refinishing the engine bay to look factory new. So I'm spending some pretty good money getting everything together. I don't know if the CS needs it or not, but I'm going to go ahead and replace the ibeam and radius arm bushings. So I bought the front end off of a very nice F350. The F350 brakes had just been rebuilt and look brand new. I also go the complete rear out of the F350 too. I only paid $150 for the complete front and rear suspension/brakes/everything from the F350. I thought it would be more cost effective to swap to (almost) brand new F350 front end into the F250 than rebuild everything on the F250. Seems like the same amount of work either way, so its just the money.
thanks
Austin
thanks
Austin
Ok Ok. If you go back and read my original post, at least I do say the F250 brakes are old and have been sitting for a while. I guess I should have mentioned that the F350 disc brakes were almost brand new and the F250 disc brakes had been sitting since 1979.
thanks
Austin
Oh yeah. Another point. I just asked if they would swap over. I didn't think my reason for doing so was relevant. So
thanks
Austin
f100today
04-02-2016 08:09 PM
Serfbored
02-28-2014 01:04 AM
Jmudder79
11-23-2007 02:53 PM
highway90
02-04-2006 11:00 AM
carrojp
04-24-2003 10:51 AM
