6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Cutting off the Diesel Partical Filter Legal???
Old 11-26-2006, 08:17 PM
DFord79's Avatar
DFord79
DFord79 is offline
IF you have money to burn....I am sure their will be after market devices for the 6.4 as there is for all the rest of the diesels....IT IS ILLEGAL TO REMOVE THE KAT AND PARTICULATE FILTER. AS OF JAN 1ST 08. now that being said...you can remove em and stay out of prison...but...if your less than a NASA engineer you will never figure out how to make em run if you do remove the cat and particulate filter. They are not like the older catilysts. Everything is tied together. I READ......go to california dept. of licensing/smog control. IF you can't pass the tests starting in JAN 07......your dirvers license will suddenly dissapear....GOD DAMN...HITLER MUST BE IN CHARGE.
CALIF-F250MAN
Modular V8 (4.6L, 5.4L)
11-09-2010 11:40 PM
rtp717
01-14-2005 10:01 PM
robraz
10-22-2004 07:51 PM
elkhunter2
Oil & Lubrication
04-09-2004 12:55 AM
FS88Bronco
10-04-2002 12:06 PM
Quick Reply: Cutting off the Diesel Partical Filter Legal???
