1995 Ford F-150 with 4.9L... towing capabilities??
Old 09-29-2006, 03:56 PM
FyreLance's Avatar
FyreLance
FyreLance is offline
I have a 1995 F-150 with the 5-speed and the 4.9L engine. It is high mileage but very well maintained. I was wondering what kind of towing capability it has. It is hard to find towing information for the 6-cyl. trucks as I'm sure it is done much less often.
I actually only want to occaisionally tow my Trans Am to the track so that when I break it racing I can get it home. Is this possible, with a flat-bed or a dolly, as long as it's only done a few times a year?
Due to the fact that my buddy and I towed my Firebird Formula with his Bronco II and a tow strap with no problem, and I've hauled some hefty loads in my truck myself, it seems like it would handle it fine... but I wanted to get some advice. I am new to towing!
Old 09-30-2006, 05:23 AM
Sycostang67's Avatar
Sycostang67
Sycostang67 is offline
Your truck should handle that with no problem. The 4.9 is a torquey motor. My friend once pulled his Trans Am on a dolley with a 2.8 S-10. It did pretty well, much better than I had expected.
Old 10-01-2006, 10:38 AM
kcw12's Avatar
kcw12
kcw12 is offline
If you cant tow it 365 days a year somethings wrong. Ive towed 6 tons up very steep hills w/ my f150 300 six 5 speed. I Dont recommend it. but i had to get the cars and trailer up the hill.
Old 10-02-2006, 06:33 AM
DT 466Man's Avatar
DT 466Man
DT 466Man is offline
trans am is nothing, 6tons of gravel on a 1ton trailer and i had enough power to go faster than 70 on the interstate, although i didn't. now braking was another story, it had no trailer brakes.
pulling it is not a problem, stopping it is
Old 10-02-2006, 07:51 AM
FyreLance's Avatar
FyreLance
Thank you guys for the tips! I just wanted to be sure.
Old 10-04-2006, 12:40 PM
Toyman's Avatar
Toyman
Toyman is offline
According to the Ford tow guide your truck should tow 3200#.
Toyman
Old 10-04-2006, 01:25 PM
FyreLance's Avatar
FyreLance
That's a little under, but for only occaisional use it should be fine, yes?
Old 10-04-2006, 01:38 PM
andym's Avatar
andym
andym is offline
Ford under-rates the tow capacity of the 300. You will be fine towing that car behind your truck every day if you wanted.
Old 10-04-2006, 01:39 PM
FyreLance's Avatar
FyreLance
Great to know!
Old 10-04-2006, 07:52 PM
chrono4's Avatar
chrono4
chrono4 is offline
My last scraping truck was a 89 f150 with a 300 and a 5 speed, and I've pulled over 5 ton behind it, its all about gearing. If your truck has highway gears, it'll do it, it will just be doggy starting off. Now stoping, if the trailer/dolley doesnt have trailer brakes (mine doesnt) then you really need to be watching and give yourself the extra room. If you do pull it, go in the country and try some panic stops, see how it reacts to it.
yoda
17
08-11-2015 01:00 PM
99 f150
6.7L Power Stroke Diesel
04-08-2015 08:52 PM
JMyers0901
05-09-2014 09:01 AM
fiveohpatrol
2009 - 2014 F150
27
11-14-2013 06:41 PM
mbutts
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
17
11-09-2011 11:05 AM
Quick Reply: 1995 Ford F-150 with 4.9L... towing capabilities??
