Bad miss
Bad miss
I have a 1997 F150 with the 4.6L. It is a 4x4 extended cab with 198,000 miles on it. The engine has developed a really bad miss. I changed the plugs about 10,000 miles ago. What are some of the things I should take a look at?
This truck also has a terrible squeaking noise in the left front suspension. Could this be the lower a-arm bushing? What can I do to make the noise go away other than replacement?
Bad miss
I had it scanned at Autozone when I had the check engine light flashing. It said I had a lean mis-fire on the #2 cylinder. I found that the injector had come unplugged at the time. I plugged it back in and it ran fine until recently. The clip on this injector does not seem to hold tight. Every time I check it though it appears that the injector is plugged in so that lead me to believe I have a different problem.
Any thoughts on the squeak??? Thanks!
How long ago was that scan? I would have it scanned again if you don't think it's the same problem.
Trying to take a shot in the dark on a miss like that isn't going to be very fruitful. If you at least knew which cylinder it is, we could start with a diagnosis. For example, if you knew for a fact it was the #2 again, I first clean the connection for the injector and secure it to the injector. Then test it. If it still misfired, I would replace that spark plug and test. If it still misfired, I would swap a COP with another cylinder and test. Misses on the same cylinder? You're back to square one and maybe you've got a bad injector or a bad connection to the injector. Know what I mean? It's just hard to tell without knowing which cylinder.
I would fix it asap so you don't mess up your catalytic converter(s). If you had a flashing check engine light, your cats may have already taken some damage.
Sorry, I'm pretty inexperienced with front-end stuff so I've got nothin' on the squeaking.
Bad miss
I think I will take it in and have a complete tune up done. When I changed the plugs the one on the rear passenger side was nearly impossible to get to with the tools I have.
I think the Cat. converter has went bad, too. Maybe time for the exhaust my son keeps after me about getting!
Question: what is a COP? I have never heard that term.
Thanks, guys!
Thanks, guys!
A COP is a Coil-On-Plug system. Instead of plug wires, I have individual coils that sit right over each spark plug. But like Lariat97 pointed out, the 97's didn't have them. My mistake.
You can test the Cat with a vacuum test, but if after you get a tune-up you're having problems getting higher RPM's, it's a safe bet that your cat is clogged. Most likely cause in this case would be unburned fuel leaking into exhaust system and combusting there.
Bad miss
Thanks for the info on COP. I had never heard of that. I think a good tune up is in order for my truck.
One more question unrelated, my son's 1987 f150 4x4 has a noise in the left front hub area when he turns. It is a "clanking" noise. I have checked the wheel bearings and they are very good. I can move the drive axle with my hand when I have the hub off. Not rotate but move it up and down a little. If anyone has any thoughts on this I would appreciate hearing them!
Thanks!
Thanks!
If you do decide to beef up your ignition system, please take a look at our F-150 Firepower Ignition System at:
http://www.performancedistributors.c...50ignition.htm
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
FTE Sponsor
