changing my front end
Old 09-19-2006, 11:47 PM
doug2000's Avatar
doug2000
doug2000 is offline
Talking changing my front end
Hi my name is Doug and i have a f250 2000 super duty 4x4 and i would like to take the old head lights out and change them to the new one like in the 2004 to 06 can that be done and if so how and what do i have to do
Old 09-20-2006, 01:13 AM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
The 04 and 06 lights are completely different and are not easily interchangeable.
It is an easy swap to go from the 2000 lights to the 03-04 jewelled lights though. Plug-n-play.
Welcome to FTE!
Old 09-20-2006, 01:21 AM
doug2000's Avatar
doug2000
doug2000 is offline
thank you
thanks for the reply and where do i go to get info on plug-n-play just new on the computer and learning how to do all this
Old 09-20-2006, 03:02 AM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
What I mean by Plug-n-play is that all yu have to do is pull the old lights out and put in the new ones. No wires to splice, no cutting, no fabrication, no nothing.
However, that is only with the 02-04 jewelled lights. Once you get into the 05+ lights you have changes to make that involve some cutting and such. If you do an 05 light conversion, might as well go all the way and slap on a whole new front end.
Old 09-20-2006, 03:41 AM
doug2000's Avatar
doug2000
doug2000 is offline
Ok got it thanks again for the quick reply but the plug-n are they like what i got or are they like the ones in the 05-06s?
Old 09-20-2006, 05:23 AM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
The 02-04 lights' plug is the same as your 2000.
Old 09-22-2006, 10:22 PM
doug2000's Avatar
doug2000
doug2000 is offline
the you again for the reply i am going to try that
Old 09-24-2006, 11:17 AM
doug2000's Avatar
doug2000
doug2000 is offline
thank you again i mean sorry about the spelling
Old 09-24-2006, 11:33 AM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
You're welcome and I never worry about spelling.
Old 10-05-2006, 06:56 PM
cumminpwr11's Avatar
cumminpwr11
cumminpwr11 is offline
Doug
www.Blackclouddiesel.com
If you truely want to run the 2005-2006, theirs is the easiest kit that I have seen. Not to badly price if you compare to the stealerships. Good luck
Chris
Old 10-05-2006, 08:11 PM
doug2000's Avatar
doug2000
doug2000 is offline
Smile your info
great thanks for the info checking it out right now let you know what i find out.
Thaks again
Doug2000
Old 10-08-2006, 07:38 PM
caddys83's Avatar
caddys83
caddys83 is offline
I use there plug and play kit for my update front end. real simple and easy to install.
Old 10-09-2006, 12:53 AM
RACERX7775's Avatar
RACERX7775
RACERX7775 is offline
hey caddys83, off the subject but, your pics throw me off a little. first pics show no front hubs, no 4x4 selector on dash, and says 4x2 on the description. there are a couple of different excursions in your gallery, is yours 4x2 and the others 4x4?
Old 10-09-2006, 09:04 AM
caddys83's Avatar
caddys83
caddys83 is offline
When I wrote 4x2 meaning 4 wheels powered by 2 wheels (RWD)
Check this site out for the meaning of 4x2 http://www.4x4abc.com/4WD101/4x4.html
I do have 2 "other excursions" my gallery but I don't think they are inrelate to what you are asking. I'm thinking The pics below is what you are asking.
the update Excursions that you see on my gallery is the same Excursion
The old look
and the update... The front hub in the pics below is the same hub. I just update the rims to the newer Excursion "Limited" rims .The rim caps are different on the Limited rims. I did had to buy a pair of new center cap for the front. The rims originaly came from a 4X4 Excursion.
The front rim caps
Sorry for the off topic, here is the harness I bought from www.Blackclouddiesel.com for the plug-n-play harness for the update headlamps.
auto doug
05-14-2013 03:30 PM
doug-here
2004 - 2008 F150
07-11-2012 06:58 PM
steisler
Modular V10 (6.8l)
46
04-24-2009 09:10 PM
djf48
02-25-2007 01:34 AM
xr4dude
01-19-2004 10:32 AM
Quick Reply: changing my front end
