Patch Panels...who's the best source???
I have used EMS panels for other restoration projects but now that I have gotten into the F100s I see that there are even more options/sources. Midfifty, Dennis Carpenter, etc all advertise repair panels (and most say that their product is superior to "other" vendors products)...I am looking for the ground truth on which panels are REALLY the best. Would appreciate any firsthand experiences, either pro or con, with these products before I invest a lot of cash. Thanks...
My experience with patch panels is they sometimes are close to fitting, but it is up to the customer to make it fit right. All of the cowl panels and the rear cab corner panels that are sold come from the same manufacturer. I had pretty good luck with the cowl panels, but the rear corners are pretty much a joke. I bought the cowl panels from Mid-fifty and the corners from BOTP.
Jeff
Jeff
Haven't seen anyone offering roof patch panels, but it's not a complex shaped area to make your own. Don't try to do the whole length in one piece, cut out a section, fit and weld in a replacement patch, move down and cut another section out and replace it. I'd do no more than 1/3 the length at a time, that way you won't have problems with supporting the roof or it going out of alignment. Do the corners last. You may be able to make the corners out of an exhaust pipe bend of the right diameter and radius or a rear cab corner patch if you don't want to try to form the curve yourself. It's not very hard to form that shape from flat metal with a little practice of the right technique.
If there is enough interest I could do an article on metal shaping.
Nuthin,
I too needed to repair the roof as it was rotted out above the gutter. Depending on how bad, i.e. how high up the rot goes you may be able to do what i did.
I cut the rot out pretty much as AX describes, a bit at a time and found that I could replace the material with flat sheet cut into strips then just a little persuation for the final shaping.
If you want to see what I mean there are quite a few pics on my site under build/Cab.
Cheers
Lee
Cheers
Lee
Jeff
Jeff
Originally Posted by CharlieLed
That's interesting, it sounds like the answer may be "you pay your money and take your chances".
Jeff
Patck Panels
I just finished putting all four corner patch panels on my 53. My experience echos what others have said. They are somewhat close but need allot of massaging. The bend radii in the area that wraps into the door openings are way too big, they have to be closed up. On the rear, there was not enough material in the area that goes into the door openings, there were wrinkles, some of the wrinkles ending up being folded over each other so there ended up being 3 layers of material. Be prepared to make patch panels to add to the patch panels. Mine came from Mid-Fifty.
When you consider confidence in my metal shaping skills (zero), and the fact that the ones out there now are only $30, I'd probably pay at least twice that to avoid having to modify the junk patch panels if it was required for my truck. It's enough of a challenge just to learn how to weld straight.
The rust through on my truck isn't that extensive, though, and it doesn't approach the doors. I'm hoping I can get away with a round patch that's only about 6" by 6" on the bottom curve of the rear cab corner.
For myself, not having either the skills or equipment, I'd cheerfully pay double as well. When you're stuck with relying on someone else to set the patch, you really don't want much room for error. It'd be well worth it.
Thinking of providing a service to your less-able friends, are you?
