1997 engine code says misfire
Old 09-09-2006, 05:44 AM
dickisonmark's Avatar
dickisonmark
dickisonmark is offline
Unhappy 1997 engine code says misfire
I have a 1997 F150 with a 4.6. I changed the plugs and wires, but get a engine code that says misfire cyl. 8. The coil is firing on the No. 8 position, but the truck still runs rough and the check engine light flashes from time to time while driving. Is there something else that could be giving me this code besides a misfire. Any info on this matter would be helpful.
Old 09-09-2006, 05:54 AM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your model year. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old 09-09-2006, 08:24 AM
z 97ford1's Avatar
z 97ford1
z 97ford1 is offline
I recently got a code p304 on my number four cyclinder. Found out that the wire was rubbing a moving part damaging it. Replaced and that took care of it.
Old 09-13-2006, 07:21 AM
ASR GUNS's Avatar
ASR GUNS
ASR GUNS is offline
I had the same problem on my 4.2 and the cylinder was firing at the coil, but we replaced it anyway and that fixed it. Weak coil.
Old 09-13-2006, 02:35 PM
BlueOvalFitter's Avatar
BlueOvalFitter
BlueOvalFitter is offline
Exclamation
Same problem here.The coil was the problem.
Old 09-13-2006, 02:48 PM
40LUTZAG's Avatar
40LUTZAG
40LUTZAG is offline
I have a 97 4.6 also. changed the plugs and wires and coil packs. It drove good for a year and it started doing it again a couple weeks ago. Took it to A- Zone and #3 misfire. I got looking around and the clip to my #3 fuel injector had a broken clip. I tried to rig it. But it might need to be replaced. Also if you have a K@N filter it will clog up your MAFS, and possibly have the same problems.
Old 09-13-2006, 10:10 PM
suavehorn's Avatar
suavehorn
suavehorn is offline
I have a K&N air filter as well. What is a MAF??
Also, my truck shakes , more when accelerating and lightly when sitting still. Should I just a get a new air filter and what would you recommend?
Old 09-14-2006, 08:00 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Mass Air Flow Sensor. Measures the airflow going to the trhottle body. Many users of oiled filters tend to over-oil the filter when servicing it and the excess oil fouls the sensor causing problems. Your symptoms are not among them.
You have a misfire. An air filter is not going to help it. If your CEL is on or flashing, get your codes read and see which cylinder(s) is causing the misfire. The vast majority of misfires are due to plugs, wires, COPS, or coils depending on which system is in your engine. Occasionally, misfires will be due to injectors or valve problems, but the other causes are extremely common.
Steve
Old 09-14-2006, 09:32 AM
merlynr's Avatar
merlynr
merlynr is offline
Run a can of fuel injector cleaner with about half a tank of gas and reset the cel.
Old 09-14-2006, 09:41 AM
projectSHO89
Fuel injector cleaner will have no effect on faulty plugs, wires, and coils.
Plus, the stuff in auto parts stores isn't very likely to have any measureable effect on the fuel system. Most fuels sold today have a very robust additive pack that makes most injector cleaners unneeded anyway.
Steve
Old 09-14-2006, 10:16 AM
merlynr's Avatar
merlynr
merlynr is offline
I didn't say it would. Thats why it's called fuel injector cleaner. It fixed the exact problem described above only on 99 explorer with 4.0.
