Mobil 1 "Truck and SUV" oil?
I have been using Mobil 1 5w 30 and changing at 5000 mile intervals. I recently noticed a quart of Mobil 1 5w 30 Truck and SUV oil. Does anybody know anything about this stuff, the Mobil 1 web site is kind of vague...
"Mobil 1 Truck & SUV's key benefits include:
Extra performance additive helps provide exceptional performance under all operating conditions, and additional protection for engines that operate under heavy load or stress, including towing, hauling and other severe service.
Unique fully synthetic formula helps reduce the formation of harmful engine deposits and sludge to keep engines cleaner longer.
Outstanding performance during the maximum oil change interval recommended in your owner's manual.
Approved for use and exceeds warranty requirements for gasoline, turbocharged and diesel engines in the following applications:
ACEA A1/B1, A5/B5-04
GM 6094M
Ford WSS-M2C929-A
MS-6395"
GM 6094M
Ford WSS-M2C929-A
MS-6395"
I emailed Mobil 1 to see what they said about this new product, here is their response...
"The Mobil1 Truck and SUV 5W30 has more anti-oxidants compared to the
Classic Mobil1 which will help with oil thickening, sludging and a
better choice for hard working gasoline engines. They are the same
price, so you might as well utilize the Mobil1 Truck and SUV 5W30 if it
is available to you.
Mobil1 oil filters remove 99.2% of contamination on the
multiple-pass efficiency test which is the best, has a synthetic
fiberglass media compared to paper materials used by other
manufacturer's. The product has a strong metal backplate that can handle
over 10 time the normal operating oil pressure so it will not leak or
burst and also less than 1psi initial restiction of oil flow at
start-up. As you can see, you have the best filtration and flow all in
one oil filter."
Thank you for choosing ExxonMobil products.
If you need further assistance, please contact ExxonMobil at 1-800-ASK-MOBIL
-Matt Jacob
one oil filter."
-Matt Jacob
A lot of us are still waiting for the old M1 T&S (aka Delvac1) to re-appear as M1 Turbo Diesel 5W40. Unfortunately, the Turbo Diesel bottles have yet to be seen anywhere... Except on Mobil's website-
I read the specs for 5W30 T&S and they differ from both of M1's other 5W30 (gasser) formulations which surprised me. I was really expecting a re-packaged version of one of the other M1 products.
ol-blu
10-09-2016 08:10 PM
Beachbumcook
09-07-2005 12:45 PM
redmeanstreak003
Oil & Lubrication
12-03-2004 08:04 PM
