crossmember
crossmember
I have a 55 F-100 that i installed a 302 with a c-6. I used a new motor mount and another crossmember for the tranny. what I wanted to know, if I can remove the old rear engine crossmember. As it is now, I would have to remove the engine to take out the transmission. Also how much play should there be at the driveline yoke at the transmission. I have installed a new driveline but I can push the yoke up and down a little bit. I get a little bit of vibration but the new driveline and changing the angle of the rear end has helped.
thanks for any help.
did you use a crossmember type motormount or individual ones? With the full crossmember mount IMHO it would be safe to remove all or the center portion of the bellhousing CM. The original engine used a 3 point mounting arrangement: center front and 2 sides of the bellhousing to allow frame twist. Unless you plan on offroading you won't be twisting the frame a lot.
