Where do you put the temp sender for aftermarket tranny temp gauge?
Hi, I am in the process of installing a tranny temp gauge for my truck (01 Supercrew 4X4). The B&M kit says to install the temp sender in the return line from the cooler. This to me doesn't seem right. I was wondering if the pan install (requires drilling and welding) or one of the pressure testing ports is better? Is there a prefered location?
Cheers
Spiff
Cheers
Spiff
Originally Posted by WarWagon
The return line is the proper location.
Thanks
Spiff
Originally Posted by stuart1
You want the sender in the line coming from the transmission before it enters the cooler.
That way you can monitor real time temperature.
Not after it has been cooled.
http://www.tciauto.com/tech_info/tra...expectancy.htm
I guess there are many schools of thought on this one. One thing to consider is that by putting it in the line to the cooler you are also getting the fluid after the torque converter heats it. Ideally, I guess, would be to measure it before it goes to the converter. I guess it doesn't matter, as long as "you" know where you are getting your reading.
You want the sender in the line coming from the transmission before it enters the cooler. That way you can monitor real time temperature. Not after it has been cooled.
I have to disagree with you warwagon, the primary reason is to make sure the fluid stays under 200 no matter what device heats it. If the fluid goes over 200 it begins to degrade and that lessens it's ability to lube your transmission. If the hottest your fluid hits is 200 then chances are everything is fine in transmissionland.
This works well as a stress meter too. If your transmission normally runs 130, and today you're towing over big hills and it's almost 200 then you are pushing it too hard.
on
I doubt that.
I was a transmission rebuilder long before B&M were invented.
It stands to reason the hottest fluid will be coming out of the convertor.
A sensor in the cooler line exiting the transmission prior to entering the cooler gives you real time temperature.
Then if it gets too hot you can take your foot out of it.
If it is in the return line this will show cooler temperature.
By the time this temperature reads in the hot zone it is game over for the transmission.
B&M are also the ones to tell you to leave the separator plate gaskets out of the valve body when installing one of their shift kits.
Ha.
Ha.
