6.9L Dimensions
it doesnt in any way shape or form. an np205 has a cast iron case it is gear driven it can handle way more power then a 1345 ever could. The front driveshaft is chain driven on teh 1345. It also uses atf and has a pump in there and if the pump goes out your bearings dont get any oil and ur t case goes by by
The cummins 4bt fits like a glove.
http://www.cumminsbronco.com/mission.htm
https://home.comcast.net/~jcmiley/
The 4bt's were piles you will be better off by puting an idi in there. first off parts are a lot cheaper and redily available. And you have a site like this to come to for questions there aint that many good cummins sites. Another thing is cost. You will save a lot more money puting an idi in there. Put a turbo on the idi and you will be way happy. just my .2 cents
The 4bt's were piles you will be better off by puting an idi in there. first off parts are a lot cheaper and redily available. And you have a site like this to come to for questions there aint that many good cummins sites. Another thing is cost. You will save a lot more money puting an idi in there. Put a turbo on the idi and you will be way happy. I wanted to put a cummins in my truck for a while and every one told me the same thing i am telling you now and in the lung run i figured out that for the price of my cummins swap i cou,ld build an idi with WAY more powerr. just my .2 cents
I can get a 6.9 for hundreds of $ or free, for $525 pump, turbo off junked diesel, $$ on repairs I can have a torque beast capible of well past 1000 ft/lbs of torque or 700-800 ft/lbs dependably ( want 400-550).
or
I could spend 2000$ + on a 4 cyl. I have found that too. the only thing I like about that motor is that it fits, diesel, inline. I would be better off with a ford 300 and 10 mpg I think.
or
