88 e150 dual tank- no power to fuel pumps
Hey guy's. First post on here
I have an 88 e150 econoline with a FI351 and dual gas tanks. With a friend we checked for power at the high pressure [frame mount] pump, nothing. Then we took off the line coming from the low pressure in tank pumps and tried cranking, no fuel from either tank/pump, so Im sure they have no power either. I have a new fuel pump relay to try, but I can't find the dang thing anywhere. Where is it?!? Also, the van didn't come with an owners manual, so I have no idea what fuse is for what and if its missing any [just bought the van yesterday]. Any online diagrams I can look up?
Any other idea's?
Any other idea's?
I had 2 problems:
1. The inertial shutoff switch, by the passenger's right foot, had the connector burn up. I cut it off and just wired past that switch
2. The primary wire for the fuel pump had a crappy fuseholder in it. I don't know if the original wiring had some kind of problem that prompted the replacement.
Fuel Pump Relay Location:
http://i54.photobucket.com/albums/g91/subford/Fuel/88E150FuelPumpRelay.gif
Fuse Box:
http://i54.photobucket.com/albums/g91/subford/Electrical/88Fuse.gif
Fuse Box Key:
http://i54.photobucket.com/albums/g91/subford/Electrical/88FuseK.gif
Fuel System Electrical:
http://i54.photobucket.com/albums/g91/subford/Fuel/88fuels.gif
Fuel System Mechanical:
http://i54.photobucket.com/albums/g91/subford/Fuel/88Fuelsystem.gif
Test Conn.:
http://i54.photobucket.com/albums/g91/subford/Fuel/DataLinkConn.jpg
Fuse Box:
Fuse Box Key:
Test Conn.:
Also check to make sure the Inertia Switch is not tripped.
Note that with pin#6 not shorted to ground the Fuel Pump Relay will only come on for one second after you turn the key to run and then it will go back off.
Here is a photo of the DLC and the diagram.
http://i54.photobucket.com/albums/g9...LinkConn88.gif
http://i54.photobucket.com/albums/g9...taLinkConn.jpg
The ground wire to the battery was the no power problem. Then I had to dis-connect the line before the selector valve until it pumped fuel, then the line coming out of the selector valve until it pumped, and finally the line out of the high pressure pump and ran it like that for a minute into a bucket. After a bit it picked up to a good flow rate so I gave it a try and it fired up
dougd347
15
10-29-2022 04:53 PM
vacuumbed
07-16-2014 04:24 PM
Kwikkordead
62
01-15-2011 02:40 PM
Solomon_Man
31
08-26-2010 07:02 PM
